VIrtualmin restore,Wordpress not working
Is this the correct URL?
Forbidden
You don’t have permission to access this resource.
i changed website with my domain
What PHP version was the old site using?
snip>index.php4,index.php5<snip
i was running php 7.3
OK I am going to ignore PHP → I am assuming you are on PHP 7.3 or better 8.1 (current) on the new Debian box. Though those index.php4 and index.php5 instructions suggest there is some really ancient code in the WordPress.
Virtualmin is currently on v7.8.2 again quite a bit changed from v6
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
htaccess file that is on all 3 wordpress folders
My php is rusty and my use of Apache is even rustier, but that suggests to me “forget whatever php specific version it has been coded as - just run it with the currently installed version”
It looks to me like a “Rewrite rule” has been used to “fix” a previous issue.
I’m still think mod php may have a bearing on this check the apache logs and config files for any mod php entries
how to search?
there are a lot of modules
Please wrap code in triple backticks (```) so it gets treated as formatted text and is readable (and tags and some things that look like HTML tags don’t get filtered out completely).
which code htaccess file?
If i know url of images browsing is possible
