i have installed the virtualmin and it’s worked fine i have create an account and upload a website. everything is fine. but today i need to access the virtualmin i can’t it gives me page cannot be displayed.
Works all okay for me. Please be aware that your VMin is - which is also the default setting - configured to use https instead of http. So the URL you posted shows the hint to use “https://77.68.52.128:10000” instead, which works as expected.
Which browser are you using? While I don’t believe I’ve run into this before, it’s possible your browser is objecting to seeing a self-signed SSL certificate (or some other strange issue). You might consider trying a different browser just as a test.
