I am going to buy VirtualMinPro (10 user version). I am going to use Centos 4.4
I read the FAQ and it seems to suggest I should do a very minimal OS install.
Therefore, I won’t bother to install any of the following Apache, MySQL, PHP, and Bind.
My various domains don’t have a private IP address, so I don’t think the Centros default vsftp will work for me, but you will probably install ProFTPD Server ?
After the installation Will the http document root for the users using domains be:
/home/username ?
The documentation seemed to indicate that php 5? would be installed? (I was looking for 4.x but I can probably adapt rather than downgrade)
Scripts running on the virtualmin website domains will be using something similiar to suexec or do you use suexec?
I have been practicing installing the open source version of VirtualMin and Webmin. (cdrecord didn’t work at first, but I got it to work with a simple addition of /dev/cdrom to the extra CD Record options. Maybe that will help someone.)
I almost got the open source virtual min fully working. (I think I just need to install a differnt ftp demon rather than vsftp) But I figure I’ll save some time and support you guys by paying for the super installer script.
I don’t mind re-installing the pro script a couple times, or tweaking the results, but I’m hoping if I get stuck I can get help, since I will have paid to use your super installer.
I am creating a test environment on a server at home behind a linksys firewall, so hopefully your defaults will work with that.
Thanks for any answers or observations you provide.
