it seems that perl based script fails too, here. If we try to install bugzilla the script fails.
Here is the log:
[code:1]
Install Script
In domain zimbra.test
Downloading http://ftp.mozilla.org/pub/mozilla.org/webtools/bugzilla-3.1.2.tar.gz (2195413 bytes) …
Ricevuti 1024 bytes (0 %)
Ricevuti 220160 bytes (10 %)
Ricevuti 439296 bytes (20 %)
Ricevuti 659456 bytes (30 %)
Ricevuti 878592 bytes (40 %)
Ricevuti 1097728 bytes (50 %)
Ricevuti 1317888 bytes (60 %)
Ricevuti 1537024 bytes (70 %)
Ricevuti 1757184 bytes (80 %)
Ricevuti 1976320 bytes (90 %)
Ricevuti 2195413 bytes (100 %)
…download completed.
Perl module Email::MIME::Modifier is required …
Installing Perl module Email::MIME::Modifier from CPAN …
CPAN: Storable loaded ok
Going to read /root/.cpan/Metadata
Database was generated on Wed, 02 Jan 2008 02:39:48 GMT
LWP not available
CPAN: Net::FTP loaded ok
Fetching with Net::FTP:
ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
Going to read /root/.cpan/sources/authors/01mailrc.txt.gz
LWP not available
ftp://ftp.perl.org/pub/CPAN/modules/02packages.details.txt.gz
Going to read /root/.cpan/sources/modules/02packages.details.txt.gz
Database was generated on Fri, 18 Jan 2008 05:38:15 GMT
HTTP::«»Date not available
There's a new CPAN.pm version (v1.9205) available!
[Current version is v1.7602]
You might want to try
install Bundle::CPAN
reload cpan
without quitting the current session. It should be a seamless upgrade
while we are running...
LWP not available
ftp://ftp.perl.org/pub/CPAN/modules/03modlist.data.gz
Going to read /root/.cpan/sources/modules/03modlist.data.gz
Going to write /root/.cpan/Metadata
Running install for module Email::MIME::Modifier
Running make for R/RJ/RJBS/Email-MIME-Modifier-1.442.tar.gz
CPAN: Digest::MD5 loaded ok
Checksum for /root/.cpan/sources/authors/id/R/RJ/RJBS/Email-MIME-Modifier-1.442.tar.gz ok
Scanning cache /root/.cpan/build for sizes
Email-MIME-Modifier-1.442/
Email-MIME-Modifier-1.442/Changes
Email-MIME-Modifier-1.442/MANIFEST
Email-MIME-Modifier-1.442/META.yml
Email-MIME-Modifier-1.442/Makefile.PL
Email-MIME-Modifier-1.442/README
Email-MIME-Modifier-1.442/lib/
Email-MIME-Modifier-1.442/lib/Email/
Email-MIME-Modifier-1.442/lib/Email/MIME/
Email-MIME-Modifier-1.442/lib/Email/MIME/Modifier.pm
Email-MIME-Modifier-1.442/t/
Email-MIME-Modifier-1.442/t/content_id.t
Email-MIME-Modifier-1.442/t/ct_attrs.t
Email-MIME-Modifier-1.442/t/disposition.t
Email-MIME-Modifier-1.442/t/encoding.t
Email-MIME-Modifier-1.442/t/parts.t
Email-MIME-Modifier-1.442/t/pod-coverage.t
Email-MIME-Modifier-1.442/t/pod.t
Removing previously used /root/.cpan/build/Email-MIME-Modifier-1.442
CPAN.pm: Going to build R/RJ/RJBS/Email-MIME-Modifier-1.442.tar.gz
Checking if your kit is complete...
Looks good
'LICENSE' is not a known MakeMaker parameter name.
Writing Makefile for Email::MIME::Modifier
---- Unsatisfied dependencies detected during [R/RJ/RJBS/Email-MIME-Modifier-1.442.tar.gz] -----
Email::MIME
Email::MIME::Encodings
Email::MessageID
Email::MIME::ContentType
Shall I follow them and prepend them to the queue
of modules we are processing right now? [yes] cp lib/Email/MIME/Modifier.pm blib/lib/Email/MIME/Modifier.pm
Manifying blib/man3/Email::MIME::Modifier.3pm
/usr/bin/make -- OK
Running make test
PERL_DL_NONLAZY=1 /usr/bin/perl5.8.8 "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/content_id......dubious
Test returned status 255 (wstat 65280, 0xff00)
DIED. FAILED tests 1-15
Failed 15/15 tests, 0.00% okay
t/ct_attrs........dubious
DIED. FAILED tests 1-10
Failed 10/10 tests, 0.00% okay
t/disposition.....dubious
DIED. FAILED tests 1-7
Failed 7/7 tests, 0.00% okay
t/encoding........dubious
DIED. FAILED tests 1-14
Failed 14/14 tests, 0.00% okay
t/parts...........dubious
DIED. FAILED tests 1-22
Failed 22/22 tests, 0.00% okay
t/pod-coverage....skipped
all skipped: Test::«»Pod::Coverage 1.08 required for testing POD coverage
t/pod.............skipped
all skipped: Test::«»Pod 1.14 required for testing POD
Failed Test Stat Wstat Total Fail List of Failed
t/content_id.t 255 65280 15 29 1-15
t/ct_attrs.t 255 65280 10 17 1-10
t/disposition.t 255 65280 7 12 1-7
t/encoding.t 255 65280 14 26 1-14
t/parts.t 255 65280 22 42 1-22
2 tests skipped.
Failed 5/7 test scripts. 68/68 subtests failed.
Files=7, Tests=68, 0 wallclock secs ( 0.16 cusr + 0.08 csys = 0.24 CPU)
/usr/bin/make test -- NOT OK
Running make install
make test had returned bad status, won't install without force
… done
Perl module DBD::mysql is required …
Installing Perl module DBD::mysql from CPAN …
Running install for module DBD::mysql
Running make for C/CA/CAPTTOFU/DBD-mysql-4.006.tar.gz
Checksum for /root/.cpan/sources/authors/id/C/CA/CAPTTOFU/DBD-mysql-4.006.tar.gz ok
DBD-mysql-4.006/
DBD-mysql-4.006/ChangeLog
DBD-mysql-4.006/constants.h
DBD-mysql-4.006/dbdimp.c
DBD-mysql-4.006/dbdimp.h
DBD-mysql-4.006/eg/
DBD-mysql-4.006/eg/._bug14979.pl
DBD-mysql-4.006/eg/bug14979.pl
DBD-mysql-4.006/eg/._bug21028.pl
DBD-mysql-4.006/eg/bug21028.pl
DBD-mysql-4.006/eg/bug30033.pl
DBD-mysql-4.006/eg/bug30033pg.pl
DBD-mysql-4.006/eg/decimal_test.pl
DBD-mysql-4.006/eg/issue21946.pl
DBD-mysql-4.006/eg/prepare_memory_usage.pl
DBD-mysql-4.006/eg/proc_example1.pl
DBD-mysql-4.006/eg/proc_example2.pl
DBD-mysql-4.006/eg/proc_example2a.pl
DBD-mysql-4.006/eg/proc_example2b.pl
DBD-mysql-4.006/eg/proc_example3.pl
DBD-mysql-4.006/eg/proc_example4.pl
DBD-mysql-4.006/INSTALL.html
DBD-mysql-4.006/lib/
DBD-mysql-4.006/lib/Bundle/
DBD-mysql-4.006/lib/Bundle/DBD/
DBD-mysql-4.006/lib/Bundle/DBD/mysql.pm
DBD-mysql-4.006/lib/DBD/
DBD-mysql-4.006/lib/DBD/mysql/
DBD-mysql-4.006/lib/DBD/mysql/GetInfo.pm
DBD-mysql-4.006/lib/DBD/mysql/INSTALL.pod
DBD-mysql-4.006/lib/DBD/mysql.pm
DBD-mysql-4.006/Makefile.PL
DBD-mysql-4.006/Makefile.PL.embedded
DBD-mysql-4.006/MANIFEST
DBD-mysql-4.006/MANIFEST.SKIP
DBD-mysql-4.006/META.yml
DBD-mysql-4.006/myld
DBD-mysql-4.006/mysql.xs
DBD-mysql-4.006/README
DBD-mysql-4.006/t/
DBD-mysql-4.006/t/00base.t
DBD-mysql-4.006/t/10connect.t
DBD-mysql-4.006/t/20createdrop.t
DBD-mysql-4.006/t/25lockunlock.t
DBD-mysql-4.006/t/30insertfetch.t
DBD-mysql-4.006/t/35limit.t
DBD-mysql-4.006/t/35prepare.t
DBD-mysql-4.006/t/40bindparam.t
DBD-mysql-4.006/t/40bindparam2.t
DBD-mysql-4.006/t/40blobs.t
DBD-mysql-4.006/t/40catalog.t
DBD-mysql-4.006/t/40keyinfo.t
DBD-mysql-4.006/t/40listfields.t
DBD-mysql-4.006/t/40nulls.t
DBD-mysql-4.006/t/40numrows.t
DBD-mysql-4.006/t/40server_prepare.t
DBD-mysql-4.006/t/40types.t
DBD-mysql-4.006/t/41bindparam.t
DBD-mysql-4.006/t/41blobs_prepare.t
DBD-mysql-4.006/t/42bindparam.t
DBD-mysql-4.006/t/50chopblanks.t
DBD-mysql-4.006/t/50commit.t
DBD-mysql-4.006/t/60leaks.t
DBD-mysql-4.006/t/65types.t
DBD-mysql-4.006/t/70takeimp.t
DBD-mysql-4.006/t/75supported_sql.t
DBD-mysql-4.006/t/80procs.t
DBD-mysql-4.006/t/insertid.t
DBD-mysql-4.006/t/lib.pl
DBD-mysql-4.006/t/multi_statement.t
DBD-mysql-4.006/t/mysql.dbtest
DBD-mysql-4.006/t/param_values.t
DBD-mysql-4.006/t/prepare_noerror.t
DBD-mysql-4.006/t/test.pl
DBD-mysql-4.006/t/test_data.txt
DBD-mysql-4.006/t/texecute.t
DBD-mysql-4.006/t/utf8.t
DBD-mysql-4.006/t/warnings.t
DBD-mysql-4.006/TODO
Removing previously used /root/.cpan/build/DBD-mysql-4.006
CPAN.pm: Going to build C/CA/CAPTTOFU/DBD-mysql-4.006.tar.gz
I will use the following settings for compiling and testing:
cflags (mysql_config) = -I/usr/include/mysql -DHAVE_ERRNO_AS_DEFINE=1
embedded (mysql_config) =
libs (mysql_config) = -L/usr/lib64/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib64 -lssl -lcrypto
mysql_config (guessed ) = mysql_config
nocatchstderr (default ) = 0
nofoundrows (default ) = 0
ssl (guessed ) = 1
testdb (default ) = test
testhost (default ) =
testpassword (default ) =
testsocket (default ) =
testuser (default ) =
To change these settings, see 'perl Makefile.PL --help' and
'perldoc INSTALL'.
Looks good
Using DBI 1.601 (for perl 5.008008 on x86_64-linux) installed in /usr/lib64/perl5/site_perl/5.8.8/x86_64-linux/auto/DBI/
Writing Makefile for DBD::mysql
cp lib/DBD/mysql.pm blib/lib/DBD/mysql.pm
cp lib/DBD/mysql/GetInfo.pm blib/lib/DBD/mysql/GetInfo.pm
cp lib/DBD/mysql/INSTALL.pod blib/lib/DBD/mysql/INSTALL.pod
cp lib/Bundle/DBD/mysql.pm blib/lib/Bundle/DBD/mysql.pm
x86_64-pc-linux-gnu-gcc -c -I/usr/lib64/perl5/site_perl/5.8.8/x86_64-linux/auto/DBI -I/usr/include/mysql -DHAVE_ERRNO_AS_DEFINE=1 -DDBD_MYSQL_WITH_SSL -DDBD_MYSQL_INSERT_ID_IS_GOOD -g -fno-strict-aliasing -pipe -Wdeclaration-after-statement -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -pipe -fforce-addr -DVERSION=\"4.006\" -DXS_VERSION=\"4.006\" -fPIC "-I/usr/lib64/perl5/5.8.8/x86_64-linux/CORE" dbdimp.c
/usr/bin/perl5.8.8 -p -e "s/~DRIVER~/mysql/g" /usr/lib64/perl5/site_perl/5.8.8/x86_64-linux/auto/DBI/Driver.xst > mysql.xsi
/usr/bin/perl5.8.8 /usr/lib64/perl5/5.8.8/ExtUtils/xsubpp -typemap /usr/lib64/perl5/5.8.8/ExtUtils/typemap mysql.xs > mysql.xsc && mv mysql.xsc mysql.c
x86_64-pc-linux-gnu-gcc -c -I/usr/lib64/perl5/site_perl/5.8.8/x86_64-linux/auto/DBI -I/usr/include/mysql -DHAVE_ERRNO_AS_DEFINE=1 -DDBD_MYSQL_WITH_SSL -DDBD_MYSQL_INSERT_ID_IS_GOOD -g -fno-strict-aliasing -pipe -Wdeclaration-after-statement -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -pipe -fforce-addr -DVERSION=\"4.006\" -DXS_VERSION=\"4.006\" -fPIC "-I/usr/lib64/perl5/5.8.8/x86_64-linux/CORE" mysql.c
Running Mkbootstrap for DBD::mysql ()
chmod 644 mysql.bs
rm -f blib/arch/auto/DBD/mysql/mysql.so
/usr/bin/perl5.8.8 myld x86_64-pc-linux-gnu-gcc -shared -L/usr/local/lib64 dbdimp.o mysql.o -o blib/arch/auto/DBD/mysql/mysql.so \
-L/usr/lib64/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib64 -lssl -lcrypto \
chmod 755 blib/arch/auto/DBD/mysql/mysql.so
cp mysql.bs blib/arch/auto/DBD/mysql/mysql.bs
chmod 644 blib/arch/auto/DBD/mysql/mysql.bs
Manifying blib/man3/DBD::mysql.3pm
Manifying blib/man3/DBD::mysql::INSTALL.3pm
Manifying blib/man3/Bundle::«»DBD::mysql.3pm
/usr/bin/make -- OK
Running make test
t/00base..............ok
t/10connect...........dubious
Failed 2/2 tests, 0.00% okay
t/20createdrop........dubious
DIED. FAILED tests 1-4
Failed 4/4 tests, 0.00% okay
t/25lockunlock........dubious
Test returned status 10 (wstat 2560, 0xa00)
DIED. FAILED tests 1-13
Failed 13/13 tests, 0.00% okay
t/30insertfetch.......dubious
DIED. FAILED tests 1-9
Failed 9/9 tests, 0.00% okay
t/35limit.............dubious
DIED. FAILED tests 1-111
Failed 111/111 tests, 0.00% okay
t/35prepare...........dubious
DIED. FAILED tests 1-49
Failed 49/49 tests, 0.00% okay
t/40bindparam.........dubious
t/40bindparam2........dubious
t/40blobs.............dubious
Failed 11/11 tests, 0.00% okay
t/40catalog...........dubious
t/40keyinfo...........dubious
t/40listfields........dubious
DIED. FAILED tests 1-19
Failed 19/19 tests, 0.00% okay
t/40nulls.............dubious
t/40numrows...........dubious
DIED. FAILED tests 1-25
Failed 25/25 tests, 0.00% okay
t/40server_prepare....dubious
t/40types.............dubious
t/41bindparam.........dubious
t/41blobs_prepare.....dubious
DIED. FAILED tests 1-24
Failed 24/24 tests, 0.00% okay
t/42bindparam.........dubious
t/50chopblanks........dubious
DIED. FAILED tests 1-35
Failed 35/35 tests, 0.00% okay
t/50commit............dubious
DIED. FAILED tests 1-30
Failed 30/30 tests, 0.00% okay
t/60leaks.............skipped
all skipped: $ENV{SLOW_TESTS} is not set
t/65types.............dubious
DIED. FAILED tests 1-20
Failed 20/20 tests, 0.00% okay
t/70takeimp...........skipped
all skipped: test feature not implemented
t/75supported_sql.....dubious
DIED. FAILED tests 1-16
Failed 16/16 tests, 0.00% okay
t/80procs.............dubious
t/insertid............dubious
t/multi_statement.....dubious
t/param_values........dubious
DIED. FAILED tests 1-8
Failed 8/8 tests, 0.00% okay
t/prepare_noerror.....dubious
t/texecute............dubious
t/utf8................dubious
t/warnings............dubious
t/10connect.t 255 65280 2 4 1-2
t/20createdrop.t 255 65280 4 8 1-4
t/25lockunlock.t 10 2560 13 25 1-13
t/30insertfetch.t 255 65280 9 18 1-9
t/35limit.t 255 65280 111 222 1-111
t/35prepare.t 255 65280 49 98 1-49
t/40bindparam.t 255 65280 ?? ?? ??
t/40bindparam2.t 10 2560 13 25 1-13
t/40blobs.t 10 2560 11 21 1-11
t/40catalog.t 255 65280 ?? ?? ??
t/40keyinfo.t 255 65280 7 14 1-7
t/40listfields.t 10 2560 19 37 1-19
t/40nulls.t 10 2560 11 21 1-11
t/40numrows.t 10 2560 25 49 1-25
t/40server_prepare.t 255 65280 9 18 1-9
t/40types.t 255 65280 ?? ?? ??
t/41bindparam.t 255 65280 10 20 1-10
t/41blobs_prepare.t 10 2560 24 47 1-24
t/42bindparam.t 255 65280 11 22 1-11
t/50chopblanks.t 10 2560 35 69 1-35
t/50commit.t 255 65280 30 59 1-30
t/65types.t 255 65280 20 40 1-20
t/75supported_sql.t 255 65280 16 32 1-16
t/80procs.t 255 65280 ?? ?? ??
t/insertid.t 255 65280 16 32 1-16
t/multi_statement.t 255 65280 7 14 1-7
t/param_values.t 255 65280 8 15 1-8
t/prepare_noerror.t 255 65280 ?? ?? ??
t/texecute.t 255 65280 9 17 1-9
t/utf8.t 255 65280 ?? ?? ??
t/warnings.t 255 65280 4 8 1-4
2 tests skipped.
Failed 31/34 test scripts. 473/478 subtests failed.
Files=34, Tests=478, 4 wallclock secs ( 2.46 cusr + 0.97 csys = 3.43 CPU)
… done
Now installing Bugzilla version 3.1.2 …
Bugzilla dependency problems detected :
* This is Bugzilla 3.1.2 on perl 5.8.8
* Running on Linux 2.6.20-hardened-r6 #4 SMP Fri Dec 7 09:38:37 CET 2007
Checking perl modules...
Checking for CGI (v2.93) ok: found v3.15
Checking for TimeDate (v2.21) ok: found v2.22
Checking for PathTools (v0.84) ok: found v3.12
Checking for DBI (v1.41) ok: found v1.601
Checking for Template-Toolkit (v2.12) ok: found v2.19
Checking for Email-Send (v2.00) ok: found v2.192
Checking for Email-MIME-Modifier (any) not found
Checking available perl DBD modules...
Checking for DBD-Pg (v1.45) not found
Checking for DBD-mysql (v2.9003) not found
The following Perl modules are optional:
Checking for GD (v1.20) not found
Checking for Chart (v1.0) not found
Checking for Template-GD (any) not found
Checking for GDTextUtil (any) not found
Checking for GDGraph (any) not found
Checking for XML-Twig (any) not found
Checking for MIME-tools (v5.406) not found
Checking for libwww-perl (any) not found
Checking for PatchReader (v0.9.4) not found
Checking for PerlMagick (any) not found
Checking for perl-ldap (any) not found
Checking for RadiusPerl (any) not found
Checking for SOAP-Lite (any) not found
Checking for HTML-Parser (v3.40) not found
Checking for HTML-Scrubber (any) not found
Checking for Email-MIME-Attachment-Stripper (any) not found
Checking for Email-Reply (any) not found
Checking for mod_perl (v1.999022) not found
Checking for CGI (v3.11) ok: found v3.15
Checking for Apache-DBI (v0.96) not found
* NOTE: You must run any commands listed below as root.
* REQUIRED MODULES *
* Bugzilla requires you to install some Perl modules which are either *
* missing from your system, or the version on your system is too old. *
* The latest versions of each module can be installed by running the *
* commands below. *
COMMANDS:
/usr/bin/perl5.8.8 -MCPAN -e 'install Email::MIME::Modifier'
* DATABASE ACCESS *
* In order to access your database, Bugzilla requires that the *
* correct "DBD" module be installed for the database that you are *
* running. *
* Pick and run the correct command below for the database that you *
* plan to use with Bugzilla. *
COMMANDS:
PostgreSQL: /usr/bin/perl5.8.8 -MCPAN -e 'install DBD::«»Pg'
Minimum version required: 1.45
MySQL: /usr/bin/perl5.8.8 -MCPAN -e 'install DBD::mysql'
Minimum version required: 2.9003
* OPTIONAL MODULES *
* Certain Perl modules are not required by Bugzilla, but by *
* installing the latest version you gain access to additional *
* features. *
* The optional modules you do not have installed are listed below, *
* with the name of the feature they enable. If you want to install *
* one of these modules, just run the appropriate command in the *
* "COMMANDS TO INSTALL" section. *
* MODULE NAME * ENABLES FEATURE(S) *
* GD * Graphical Reports, New Charts, Old Charts *
* Chart * New Charts, Old Charts *
* Template-GD * Graphical Reports *
* GDTextUtil * Graphical Reports *
* GDGraph * Graphical Reports *
* XML-Twig * Move Bugs Between Installations *
* MIME-tools * Move Bugs Between Installations *
* libwww-perl * Automatic Update Notifications *
* PatchReader * Patch Viewer *
* PerlMagick * Optionally Convert BMP Attachments to PNGs *
* perl-ldap * LDAP Authentication *
* RadiusPerl * RADIUS Authentication *
* SOAP-Lite * XML-RPC Interface *
* HTML-Parser * More HTML in Product/Group Descriptions *
* HTML-Scrubber * More HTML in Product/Group Descriptions *
* Email-MIME-Attachment-Stripper * Inbound Email *
* Email-Reply * Inbound Email *
* mod_perl * mod_perl *
* Apache-DBI * mod_perl *
COMMANDS TO INSTALL:
GD: /usr/bin/perl5.8.8 -MCPAN -e 'install GD'
Chart: /usr/bin/perl5.8.8 -MCPAN -e 'install Chart::Base'
Template-GD: /usr/bin/perl5.8.8 -MCPAN -e 'install Template::«»Plugin::GD::Image'
GDTextUtil: /usr/bin/perl5.8.8 -MCPAN -e 'install GD::Text'
GDGraph: /usr/bin/perl5.8.8 -MCPAN -e 'install GD::Graph'
XML-Twig: /usr/bin/perl5.8.8 -MCPAN -e 'install XML::Twig'
MIME-tools: /usr/bin/perl5.8.8 -MCPAN -e 'install MIME::«»Parser'
libwww-perl: /usr/bin/perl5.8.8 -MCPAN -e 'install LWP::UserAgent'
PatchReader: /usr/bin/perl5.8.8 -MCPAN -e 'install PatchReader'
PerlMagick: /usr/bin/perl5.8.8 -MCPAN -e 'install Image::Magick'
perl-ldap: /usr/bin/perl5.8.8 -MCPAN -e 'install Net::LDAP'
RadiusPerl: /usr/bin/perl5.8.8 -MCPAN -e 'install Authen::Radius'
SOAP-Lite: /usr/bin/perl5.8.8 -MCPAN -e 'install SOAP::Lite'
HTML-Parser: /usr/bin/perl5.8.8 -MCPAN -e 'install HTML::«»Parser'
HTML-Scrubber: /usr/bin/perl5.8.8 -MCPAN -e 'install HTML::«»Scrubber'
Email-MIME-Attachment-Stripper: /usr/bin/perl5.8.8 -MCPAN -e 'install Email::MIME::Attachment::«»Stripper'
Email-Reply: /usr/bin/perl5.8.8 -MCPAN -e 'install Email::Reply'
mod_perl: /usr/bin/perl5.8.8 -MCPAN -e 'install mod_perl2'
Apache-DBI: /usr/bin/perl5.8.8 -MCPAN -e 'install Apache::«»DBI'
More information on using this script can be found at http://www.bugzilla.org/.
… failed! See the error message above for the reason why.
[/code:1]
