Virtualmin Out of Memory Errors
Hey Guys,
A new installation of Virtualmin is running out of memory on my end … any clues ? Below is the miniserv.error
[05/Jul/2009:01:00:52 -0400] Continuing without the Authen::PAM perl module
[05/Jul/2009:01:01:56 -0400] Reloading configuration
[05/Jul/2009:01:02:14 -0400] [172.16.0.105] /left.cgi : File not found
[05/Jul/2009:01:02:21 -0400] [172.16.0.105] /left.cgi : File not found
[05/Jul/2009:01:02:22 -0400] Reloading configuration
[05/Jul/2009:01:02:33 -0400] Reloading configuration
find /usr/lib/perl5/5.8.8 -name .packlist -print
find /usr/lib/perl5/site_perl -name .packlist -print
find /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi -name .packlist -print
find /usr/lib/perl5/vendor_perl -name .packlist -print
Out of memory!
Out of memory!
Out of memory!
Out of memory!
[04/Jul/2009:22:03:03 -0400] Perl module Authen::PAM needed for PAM is not installed : Can’t locate Authen/PAM.pm in @INC (@INC contains: /usr/libexec/webmi
BEGIN failed–compilation aborted at (eval 5) line 1.
[04/Jul/2009:22:03:03 -0400] Continuing without the Authen::PAM perl module
[04/Jul/2009:22:03:48 -0400] Reloading configuration
Out of memory!
Out of memory!
*** glibc detected *** /usr/libexec/webmin/apache/index.cgi: corrupted double-linked list: 0xbfef7bc8 ***
Which version of Virtualmin are you using?
And how much RAM and swap is on your server? You can determine that with the command “free -m”.
Webmin version 1.480 Virtualmin version 3.69.gpl GPL
Real memory 1.98 GB total, 249.23 MB used
Virtual memory 1.94 GB total, 0 bytes used
Yeah, looks like you have plenty of RAM.
What do you see if you type:
dmesg | tail
Thanks!
294534 pages of HIGHMEM
7418 reserved pages
1156 pages shared
8 pages swap cached
0 pages dirty
1 pages writeback
540 pages mapped
2519 pages slab
1796 pages pagetables
Out of memory: Killed process 22404 (miniserv.pl).
Okay, I’m going to pass this onto Jamie to see if he has some thoughts on what might cause that.
Well, one more quick question – you’re not by chance attempting an upgrade, are you? There is a bug in upgrading to 3.70 that could cause an out of memory condition in certain circumstances.
Thanks,
nope no upgrades –
Though i think i caught the problem -
  1. I had somehow overwritten the perl.conf in the etc\conf.d directory with my default httpd.conf …
I renamed my perl.conf and everything seems to be running fine for now.
Could you please send me a sample perl.conf file so i can see what it looks like ? Also any idea what exactly the perl.conf does ?
Well, that could cause trouble, though it’s unrelated to Virtualmin – Virtualmin doesn’t run through Apache in any way.
The perl.conf file you’re referring to is for mod_perl in Apache. How it looks would determine which distro you’re using.
