techng
July 17, 2020, 7:17pm
1
I’ve been trying to install Virtualmin on Ubuntu 18.04 but kept hitting the error below.
[ERROR] Something went wrong. Exiting.
[ERROR] The last few log entries were:
Unpacking libmilter1.0.1:amd64 (8.15.2-10) …
Selecting previously unselected package libopendkim11.
Preparing to unpack …/204-libopendkim11_2.11.0~alpha-11build1_amd64.deb …
Unpacking libopendkim11 (2.11.0~alpha-11build1) …
Selecting previously unselected package milter-greylist.
Preparing to unpack …/205-milter-greylist_4.5.11-1.1build2_amd64.deb …
Adding group greylist…done
Adding system user greylist…done
Unpacking milter-greylist (4.5.11-1.1build2) …
/tmp/apt-dpkg-install-D8d7BE/018-webmin-virtualmin-nginx-ssl_1.11_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Installing virtualmin-lemp-stack: [2020-07-17 21:15:38 CEST] [ERROR] Failed with error: 100
[2020-07-17 21:15:38 CEST] [ERROR] Something went wrong. Exiting.
[2020-07-17 21:15:38 CEST] [ERROR] The last few log entries were:
I would appreciate any help solving this.
I just deployed 18.04 and tried a install and got warnings. screen shot below, did you get these warnings?
techng
July 17, 2020, 9:57pm
3
The warning in your screenshot is just a normal notice, type y & press enter to proceed.
all went good then, screenshot below of finish, language file needs to be fixed )
Joe
July 18, 2020, 7:40am
6
Which part of this screenshot looks like a warning to you? I’d like to make it more clear, but I don’t see how this can be interpreted as a warning?
Joe
July 18, 2020, 7:42am
7
What kind of terminal or ssh client are you using? It looks like it doesn’t support unicode, but we detected that it supports it (which is not unheard of, terminals behave wildly differently across operating systems).
Edit: Actually, that maybe looks like it not only doesn’t support Unicode, but it also doesn’t support the full set of ANSI control sequences so it’s not resetting properly on each “tick” of the progress bar.
system
Closed
August 17, 2020, 7:42am
8
