Same dedicated server, VirtualBox, different VM, same iso(CentOS5.8 x86_64), this wrong but other doesn’t.
virtualmin-install.log
INFO - 2012-09-28 18:01:53 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 18:01:53 - Install mode: full
DEBUG - 2012-09-28 18:01:53 - Product: Virtualmin GPL
DEBUG - 2012-09-28 18:01:53 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 18:01:53 - install.sh version: 1.0.9
INFO - 2012-09-28 18:01:53 - Checking for fully qualified hostname…
INFO - 2012-09-28 18:01:53 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 18:01:53 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 18:01:53 - Loading OS selection library…
INFO - 2012-09-28 18:01:54 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 18:01:54 - Loading OS list…
INFO - 2012-09-28 18:01:55 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 18:01:55 - Operating system name: CentOS Linux
INFO - 2012-09-28 18:01:55 - Operating system version: 5
INFO - 2012-09-28 18:01:55 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 18:01:55 - Disabling SELinux during installation…
INFO - 2012-09-28 18:01:55 - setenforce 0 failed: 1
INFO - 2012-09-28 18:01:56 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2012-09-28 18:02:07 - Succeeded.
INFO - 2012-09-28 18:02:07 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Loaded plugins: fastestmirror, security
Loading mirror speeds from cached hostfile
- base: mirrors.btte.net
- extras: mirrors.163.com
- updates: mirrors.btte.net
Setting up Install Process
Package procmail-3.22-17.1.el5.centos.x86_64 already installed and latest version
Package 1:quota-3.13-5.el5.x86_64 already installed and latest version
Package iptables-1.3.5-9.1.el5.x86_64 already installed and latest version
Package openssl-0.9.8e-22.el5_8.4.x86_64 already installed and latest version
Package openssl-0.9.8e-22.el5_8.4.i686 already installed and latest version
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.4-12.x86_64 already installed and latest version
Resolving Dependencies
–> Running transaction check
—> Package bind.x86_64 30:9.3.6-20.P1.el5_8.4 set to be updated
–> Processing Dependency: bind-libs = 30:9.3.6-20.P1.el5_8.4 for package: bind
—> Package bind-utils.x86_64 30:9.3.6-20.P1.el5_8.4 set to be updated
—> Package caching-nameserver.x86_64 30:9.3.6-20.P1.el5_8.4 set to be updated
—> Package cyrus-sasl.i386 0:2.1.22-7.el5_8.1 set to be updated
–> Processing Dependency: cyrus-sasl-lib = 2.1.22-7.el5_8.1 for package: cyrus-sasl
—> Package cyrus-sasl.x86_64 0:2.1.22-7.el5_8.1 set to be updated
—> Package cyrus-sasl-gssapi.i386 0:2.1.22-7.el5_8.1 set to be updated
—> Package cyrus-sasl-gssapi.x86_64 0:2.1.22-7.el5_8.1 set to be updated
—> Package dovecot.x86_64 0:1.0.7-7.el5_7.1 set to be updated
–> Processing Dependency: libpq.so.4()(64bit) for package: dovecot
—> Package httpd.x86_64 1:2.2.3-63.1.vm set to be updated
–> Processing Dependency: libaprutil-1.so.0()(64bit) for package: httpd
–> Processing Dependency: libapr-1.so.0()(64bit) for package: httpd
—> Package mailman.x86_64 3:2.1.9-6.el5_6.1 set to be updated
—> Package mod_dav_svn.x86_64 0:1.6.11-10.el5_8 set to be updated
—> Package mod_perl.x86_64 0:2.0.4-6.el5 set to be updated
–> Processing Dependency: perl(BSD::Resource) for package: mod_perl
—> Package mod_python.x86_64 0:3.2.8-3.1 set to be updated
—> Package mod_ssl.x86_64 2:2.2.3-63.1.vm set to be updated
–> Processing Dependency: libdistcache.so.1()(64bit) for package: mod_ssl
–> Processing Dependency: libnal.so.1()(64bit) for package: mod_ssl
—> Package mysql.i386 0:5.0.95-1.el5_7.1 set to be updated
–> Processing Dependency: perl(DBI) for package: mysql
—> Package mysql.x86_64 0:5.0.95-1.el5_7.1 set to be updated
—> Package mysql-devel.i386 0:5.0.95-1.el5_7.1 set to be updated
—> Package mysql-devel.x86_64 0:5.0.95-1.el5_7.1 set to be updated
—> Package mysql-server.x86_64 0:5.0.95-1.el5_7.1 set to be updated
—> Package perl-Crypt-SSLeay.x86_64 0:0.51-11.el5 set to be updated
—> Package perl-DBD-MySQL.x86_64 0:3.0007-2.el5 set to be updated
—> Package perl-DBD-Pg.x86_64 0:1.49-4.el5_8 set to be updated
—> Package perl-XML-Simple.noarch 0:2.14-4.fc6 set to be updated
–> Processing Dependency: perl(XML::Parser) for package: perl-XML-Simple
—> Package php.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: php-common = 5.1.6-39.el5_8 for package: php
–> Processing Dependency: php-cli = 5.1.6-39.el5_8 for package: php
–> Processing Dependency: libgmp.so.3()(64bit) for package: php
—> Package php-gd.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-imap.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: libc-client.so.1()(64bit) for package: php-imap
—> Package php-mbstring.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-mysql.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: php-pdo for package: php-mysql
—> Package php-odbc.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: libodbc.so.1()(64bit) for package: php-odbc
—> Package php-pear.noarch 1:1.4.9-8.el5 set to be updated
–> Processing Dependency: php-devel for package: php-pear
—> Package php-pgsql.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-snmp.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: net-snmp for package: php-snmp
—> Package php-xml.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-xmlrpc.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package postfix.x86_64 2:2.3.3-2.3.el5_6 set to be updated
—> Package postgresql.x86_64 0:8.1.23-6.el5_8 set to be updated
—> Package postgresql-server.x86_64 0:8.1.23-6.el5_8 set to be updated
—> Package python.x86_64 0:2.4.3-46.el5_8.2 set to be updated
–> Processing Dependency: python-libs-x86_64 = 2.4.3-46.el5_8.2 for package: python
—> Package ruby.x86_64 0:1.8.5-24.el5 set to be updated
–> Processing Dependency: ruby-libs = 1.8.5-24.el5 for package: ruby
–> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby
—> Package ruby-devel.i386 0:1.8.5-24.el5 set to be updated
–> Processing Dependency: libruby.so.1.8 for package: ruby-devel
—> Package ruby-devel.x86_64 0:1.8.5-24.el5 set to be updated
—> Package rubygems.noarch 0:0.9.2-1.el5 set to be updated
–> Processing Dependency: ruby-rdoc for package: rubygems
—> Package spamassassin.x86_64 0:3.3.1-2.el5 set to be updated
–> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin
–> Processing Dependency: perl(NetAddr::IP) >= 4.000 for package: spamassassin
–> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin
–> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin
–> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin
–> Processing Dependency: perl(Net::DNS) for package: spamassassin
–> Processing Dependency: perl(Archive::Tar) for package: spamassassin
—> Package subversion.i386 0:1.6.11-10.el5_8 set to be updated
–> Processing Dependency: libneon.so.25 for package: subversion
–> Processing Dependency: libapr-1.so.0 for package: subversion
–> Processing Dependency: libaprutil-1.so.0 for package: subversion
—> Package subversion.x86_64 0:1.6.11-10.el5_8 set to be updated
—> Package webalizer.x86_64 0:2.01_10-30.1 set to be updated
–> Processing Dependency: libgd.so.2()(64bit) for package: webalizer
—> Package apr.i386 0:1.2.7-11.el5_6.5 set to be updated
—> Package apr.x86_64 0:1.2.7-11.el5_6.5 set to be updated
—> Package apr-util.i386 0:1.2.7-11.el5_5.2 set to be updated
–> Processing Dependency: libsqlite3.so.0 for package: apr-util
–> Processing Dependency: libpq.so.4 for package: apr-util
—> Package apr-util.x86_64 0:1.2.7-11.el5_5.2 set to be updated
—> Package bind-libs.x86_64 30:9.3.6-20.P1.el5_8.4 set to be updated
–> Processing Dependency: cyrus-sasl-lib = 2.1.22-5.el5_4.3 for package: cyrus-sasl-plain
—> Package cyrus-sasl-lib.i386 0:2.1.22-7.el5_8.1 set to be updated
—> Package cyrus-sasl-lib.x86_64 0:2.1.22-7.el5_8.1 set to be updated
—> Package distcache.x86_64 0:1.4.5-14.1 set to be updated
—> Package gd.x86_64 0:2.0.33-9.4.el5_4.2 set to be updated
–> Processing Dependency: pkgconfig for package: gd
—> Package gmp.x86_64 0:4.1.4-10.el5 set to be updated
—> Package libc-client.x86_64 0:2004g-2.2.1 set to be updated
—> Package neon.i386 0:0.25.5-10.el5_4.1 set to be updated
—> Package net-snmp.x86_64 1:5.3.2.2-17.el5_8.1 set to be updated
–> Processing Dependency: net-snmp-libs = 1:5.3.2.2-17.el5_8.1 for package: net-snmp
–> Processing Dependency: libsensors.so.3()(64bit) for package: net-snmp
—> Package perl-Archive-Tar.noarch 1:1.39.1-1.el5_5.2 set to be updated
—> Package perl-BSD-Resource.x86_64 0:1.28-1.fc6.1 set to be updated
—> Package perl-DBI.x86_64 0:1.52-2.el5 set to be updated
—> Package perl-IO-Socket-INET6.noarch 0:2.51-2.fc6 set to be updated
–> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6
—> Package perl-IO-Socket-SSL.noarch 0:1.01-1.fc6 set to be updated
—> Package perl-IO-Zlib.noarch 0:1.04-4.2.1 set to be updated
—> Package perl-Net-DNS.x86_64 0:0.59-3.el5 set to be updated
–> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS
–> Processing Dependency: perl(Net::IP) for package: perl-Net-DNS
—> Package perl-NetAddr-IP.x86_64 0:4.027-5.el5_6 set to be updated
—> Package perl-XML-Parser.x86_64 0:2.34-6.1.2.2.1 set to be updated
—> Package php-cli.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-common.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package php-devel.x86_64 0:5.1.6-39.el5_8 set to be updated
–> Processing Dependency: autoconf for package: php-devel
–> Processing Dependency: automake for package: php-devel
—> Package php-pdo.x86_64 0:5.1.6-39.el5_8 set to be updated
—> Package postgresql-libs.x86_64 0:8.1.23-6.el5_8 set to be updated
—> Package python-libs.x86_64 0:2.4.3-46.el5_8.2 set to be updated
–> Processing Dependency: libexpat.so.0(EXPAT_1_95_8_RH)(64bit) for package: python-libs
—> Package ruby-libs.i386 0:1.8.5-24.el5 set to be updated
—> Package ruby-libs.x86_64 0:1.8.5-24.el5 set to be updated
—> Package ruby-rdoc.x86_64 0:1.8.5-24.el5 set to be updated
–> Processing Dependency: ruby-irb = 1.8.5-24.el5 for package: ruby-rdoc
—> Package unixODBC-libs.x86_64 0:2.2.11-10.el5 set to be updated
—> Package autoconf.noarch 0:2.59-12 set to be updated
–> Processing Dependency: imake for package: autoconf
—> Package automake.noarch 0:1.9.6-2.3.el5 set to be updated
—> Package cyrus-sasl-plain.i386 0:2.1.22-7.el5_8.1 set to be updated
—> Package cyrus-sasl-plain.x86_64 0:2.1.22-7.el5_8.1 set to be updated
—> Package expat.i386 0:1.95.8-11.el5_8 set to be updated
—> Package expat.x86_64 0:1.95.8-11.el5_8 set to be updated
—> Package lm_sensors.x86_64 0:2.10.7-9.el5 set to be updated
—> Package net-snmp-libs.x86_64 1:5.3.2.2-17.el5_8.1 set to be updated
—> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated
–> Processing Dependency: perl(Digest::SHA1) for package: perl-Digest-HMAC
—> Package perl-Net-IP.noarch 0:1.25-2.fc6 set to be updated
—> Package perl-Socket6.x86_64 0:0.19-3.fc6 set to be updated
—> Package pkgconfig.x86_64 1:0.21-2.el5 set to be updated
—> Package postgresql-libs.i386 0:8.1.23-6.el5_8 set to be updated
—> Package ruby-irb.x86_64 0:1.8.5-24.el5 set to be updated
—> Package sqlite.i386 0:3.3.6-5 set to be updated
—> Package imake.x86_64 0:1.0.2-3 set to be updated
—> Package perl-Digest-SHA1.x86_64 0:2.11-1.2.1 set to be updated
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
bind x86_64 30:9.3.6-20.P1.el5_8.4 updates 989 k
caching-nameserver x86_64 30:9.3.6-20.P1.el5_8.4 updates 63 k
cyrus-sasl i386 2.1.22-7.el5_8.1 updates 1.2 M
cyrus-sasl-gssapi i386 2.1.22-7.el5_8.1 updates 28 k
cyrus-sasl-gssapi x86_64 2.1.22-7.el5_8.1 updates 29 k
dovecot x86_64 1.0.7-7.el5_7.1 base 1.7 M
httpd x86_64 1:2.2.3-63.1.vm virtualmin 1.3 M
mailman x86_64 3:2.1.9-6.el5_6.1 base 9.7 M
mod_dav_svn x86_64 1.6.11-10.el5_8 updates 79 k
mod_perl x86_64 2.0.4-6.el5 base 4.0 M
mod_python x86_64 3.2.8-3.1 base 260 k
mod_ssl x86_64 2:2.2.3-63.1.vm virtualmin 95 k
mysql i386 5.0.95-1.el5_7.1 updates 4.9 M
mysql x86_64 5.0.95-1.el5_7.1 updates 4.9 M
mysql-devel i386 5.0.95-1.el5_7.1 updates 2.4 M
mysql-devel x86_64 5.0.95-1.el5_7.1 updates 2.5 M
mysql-server x86_64 5.0.95-1.el5_7.1 updates 9.9 M
perl-Crypt-SSLeay x86_64 0.51-11.el5 base 45 k
perl-DBD-MySQL x86_64 3.0007-2.el5 base 148 k
perl-DBD-Pg x86_64 1.49-4.el5_8 updates 115 k
perl-XML-Simple noarch 2.14-4.fc6 base 68 k
php x86_64 5.1.6-39.el5_8 updates 2.4 M
php-gd x86_64 5.1.6-39.el5_8 updates 119 k
php-imap x86_64 5.1.6-39.el5_8 updates 56 k
php-mbstring x86_64 5.1.6-39.el5_8 updates 1.0 M
php-mysql x86_64 5.1.6-39.el5_8 updates 91 k
php-odbc x86_64 5.1.6-39.el5_8 updates 55 k
php-pear noarch 1:1.4.9-8.el5 base 344 k
php-pgsql x86_64 5.1.6-39.el5_8 updates 71 k
php-snmp x86_64 5.1.6-39.el5_8 updates 31 k
php-xml x86_64 5.1.6-39.el5_8 updates 103 k
php-xmlrpc x86_64 5.1.6-39.el5_8 updates 59 k
postfix x86_64 2:2.3.3-2.3.el5_6 base 3.7 M
postgresql x86_64 8.1.23-6.el5_8 updates 2.9 M
postgresql-server x86_64 8.1.23-6.el5_8 updates 3.9 M
ruby x86_64 1.8.5-24.el5 base 277 k
ruby-devel i386 1.8.5-24.el5 base 558 k
ruby-devel x86_64 1.8.5-24.el5 base 566 k
rubygems noarch 0.9.2-1.el5 virtualmin 497 k
spamassassin x86_64 3.3.1-2.el5 base 1.1 M
subversion i386 1.6.11-10.el5_8 updates 3.1 M
subversion x86_64 1.6.11-10.el5_8 updates 3.2 M
webalizer x86_64 2.01_10-30.1 base 112 k
Updating:
bind-utils x86_64 30:9.3.6-20.P1.el5_8.4 updates 180 k
cyrus-sasl x86_64 2.1.22-7.el5_8.1 updates 1.2 M
python x86_64 2.4.3-46.el5_8.2 updates 59 k
Installing for dependencies:
apr i386 1.2.7-11.el5_6.5 base 124 k
apr x86_64 1.2.7-11.el5_6.5 base 119 k
apr-util i386 1.2.7-11.el5_5.2 base 80 k
apr-util x86_64 1.2.7-11.el5_5.2 base 79 k
autoconf noarch 2.59-12 base 647 k
automake noarch 1.9.6-2.3.el5 base 476 k
distcache x86_64 1.4.5-14.1 base 121 k
gd x86_64 2.0.33-9.4.el5_4.2 base 155 k
gmp x86_64 4.1.4-10.el5 base 201 k
imake x86_64 1.0.2-3 base 319 k
libc-client x86_64 2004g-2.2.1 base 515 k
lm_sensors x86_64 2.10.7-9.el5 base 525 k
neon i386 0.25.5-10.el5_4.1 base 101 k
net-snmp x86_64 1:5.3.2.2-17.el5_8.1 updates 706 k
perl-Archive-Tar noarch 1:1.39.1-1.el5_5.2 base 53 k
perl-BSD-Resource x86_64 1.28-1.fc6.1 base 29 k
perl-DBI x86_64 1.52-2.el5 base 600 k
perl-Digest-HMAC noarch 1.01-15 base 12 k
perl-Digest-SHA1 x86_64 2.11-1.2.1 base 49 k
perl-IO-Socket-INET6 noarch 2.51-2.fc6 base 13 k
perl-IO-Socket-SSL noarch 1.01-1.fc6 base 49 k
perl-IO-Zlib noarch 1.04-4.2.1 base 15 k
perl-Net-DNS x86_64 0.59-3.el5 base 215 k
perl-Net-IP noarch 1.25-2.fc6 base 31 k
perl-NetAddr-IP x86_64 4.027-5.el5_6 base 109 k
perl-Socket6 x86_64 0.19-3.fc6 base 21 k
perl-XML-Parser x86_64 2.34-6.1.2.2.1 base 210 k
php-cli x86_64 5.1.6-39.el5_8 updates 2.2 M
php-common x86_64 5.1.6-39.el5_8 updates 154 k
php-devel x86_64 5.1.6-39.el5_8 updates 505 k
php-pdo x86_64 5.1.6-39.el5_8 updates 67 k
pkgconfig x86_64 1:0.21-2.el5 base 61 k
postgresql-libs i386 8.1.23-6.el5_8 updates 197 k
postgresql-libs x86_64 8.1.23-6.el5_8 updates 197 k
ruby-irb x86_64 1.8.5-24.el5 base 70 k
ruby-libs i386 1.8.5-24.el5 base 1.6 M
ruby-libs x86_64 1.8.5-24.el5 base 1.6 M
ruby-rdoc x86_64 1.8.5-24.el5 base 136 k
sqlite i386 3.3.6-5 base 213 k
unixODBC-libs x86_64 2.2.11-10.el5 base 554 k
Updating for dependencies:
bind-libs x86_64 30:9.3.6-20.P1.el5_8.4 updates 897 k
cyrus-sasl-lib i386 2.1.22-7.el5_8.1 updates 126 k
cyrus-sasl-lib x86_64 2.1.22-7.el5_8.1 updates 130 k
cyrus-sasl-plain i386 2.1.22-7.el5_8.1 updates 27 k
cyrus-sasl-plain x86_64 2.1.22-7.el5_8.1 updates 27 k
expat i386 1.95.8-11.el5_8 updates 78 k
expat x86_64 1.95.8-11.el5_8 updates 77 k
net-snmp-libs x86_64 1:5.3.2.2-17.el5_8.1 updates 1.3 M
python-libs x86_64 2.4.3-46.el5_8.2 updates 5.9 M
Transaction Summary
Install 83 Package(s)
Upgrade 12 Package(s)
Total download size: 91 M
Downloading Packages:
Total 1.4 MB/s | 91 MB 01:04
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : php-common 1/107
Updating : cyrus-sasl-lib 2/107
Updating : expat 3/107
Installing : postgresql-libs 4/107
Installing : perl-DBI 5/107
Installing : mysql 6/107
Installing : ruby-libs 7/107
Installing : apr 8/107
Updating : bind-libs 9/107
Installing : apr-util 10/107
Installing : httpd 11/107
Installing : php-pdo 12/107
Updating : net-snmp-libs 13/107
Installing : ruby 14/107
Updating : cyrus-sasl 15/107
Installing : gmp 16/107
Installing : php-cli 17/107
Installing : php 18/107
Installing : bind 19/107
Installing : perl-DBD-MySQL 20/107
Installing : postgresql 21/107
Installing : perl-XML-Parser 22/107
Updating : cyrus-sasl-plain 23/107
Installing : distcache 24/107
Installing : unixODBC-libs 25/107
Installing : perl-Socket6 26/107
Installing : perl-Digest-SHA1 27/107
Installing : imake 28/107
Installing : perl-NetAddr-IP 29/107
Installing : libc-client 30/107
Installing : perl-BSD-Resource 31/107
Installing : lm_sensors 32/107
Installing : net-snmp 33/107
Installing : pkgconfig 34/107
Updating : expat 35/107
Installing : autoconf 36/107
Installing : perl-IO-Zlib 37/107
Updating : cyrus-sasl-lib 38/107
Installing : neon 39/107
Installing : apr 40/107
Installing : gd 41/107
Installing : perl-Archive-Tar 42/107
Installing : automake 43/107
Installing : php-devel 44/107
Installing : perl-Digest-HMAC 45/107
Installing : perl-IO-Socket-INET6 46/107
Installing : ruby-irb 47/107
Installing : ruby-rdoc 48/107
Installing : perl-IO-Socket-SSL 49/107
Installing : perl-Net-IP 50/107
Installing : perl-Net-DNS 51/107
Installing : mysql 52/107
Updating : cyrus-sasl-plain 53/107
Installing : ruby-libs 54/107
Installing : sqlite 55/107
Installing : postgresql-libs 56/107
Installing : spamassassin 57/107
Installing : webalizer 58/107
Installing : php-snmp 59/107
Installing : mod_perl 60/107
Installing : php-imap 61/107
Installing : php-odbc 62/107
Installing : mod_ssl 63/107
Installing : postgresql-server 64/107
Installing : mysql-server 65/107
Installing : postfix 66/107
Installing : php-mysql 67/107
Installing : php-pgsql 68/107
Updating : bind-utils 69/107
Installing : dovecot 70/107
Installing : perl-DBD-Pg 71/107
Installing : cyrus-sasl-gssapi 72/107
Installing : php-mbstring 73/107
Installing : php-xml 74/107
Installing : php-gd 75/107
Installing : php-xmlrpc 76/107
Installing : perl-Crypt-SSLeay 77/107
Installing : apr-util 78/107
Installing : cyrus-sasl 79/107
Installing : cyrus-sasl-gssapi 80/107
Installing : ruby-devel 81/107
Installing : mysql-devel 82/107
Installing : rubygems 83/107
Installing : php-pear 84/107
Installing : perl-XML-Simple 85/107
Installing : caching-nameserver 86/107
Installing : ruby-devel 87/107
Installing : mysql-devel 88/107
Updating : python 89/107
Updating : python-libs 90/107
Installing : subversion 91/107
Installing : subversion 92/107
Installing : mod_dav_svn 93/107
Installing : mod_python 94/107
Installing : mailman 95/107
Cleanup : python 96/107
Cleanup : cyrus-sasl 97/107
Cleanup : python-libs 98/107
Cleanup : net-snmp-libs 99/107
Cleanup : expat 100/107
Cleanup : bind-utils 101/107
Cleanup : bind-libs 102/107
Cleanup : cyrus-sasl-lib 103/107
Cleanup : cyrus-sasl-plain 104/107
Cleanup : expat 105/107
Cleanup : cyrus-sasl-lib 106/107
Cleanup : cyrus-sasl-plain 107/107
Installed:
Dependency Installed:
Updated:
bind-utils.x86_64 30:9.3.6-20.P1.el5_8.4 cyrus-sasl.x86_64 0:2.1.22-7.el5_8.1
Dependency Updated:
Complete!
INFO - 2012-09-28 18:04:07 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 18:04:07 - Succeeded.
INFO - 2012-09-28 18:04:07 - Installing Virtualmin and all related packages now using the command:
INFO - 2012-09-28 18:04:07 - yum clean all
INFO - 2012-09-28 18:04:09 - yum -y -d 2 install virtualmin-base
Determining fastest mirrors
- extras: mirrors.stuhome.net
—> Package virtualmin-base.noarch 0:1.0-61.rh set to be updated
–> Processing Dependency: webmin >= 1.334 for package: virtualmin-base
–> Processing Dependency: usermin >= 1.160 for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-svn for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-init for package: virtualmin-base
–> Processing Dependency: cyrus-sasl-md5 for package: virtualmin-base
–> Processing Dependency: clamav for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-dav for package: virtualmin-base
–> Processing Dependency: proftpd for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-htpasswd for package: virtualmin-base
–> Processing Dependency: wbm-ruby-gems for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-mailman for package: virtualmin-base
–> Processing Dependency: mod_fcgid for package: virtualmin-base
–> Processing Dependency: /usr/sbin/clamd for package: virtualmin-base
–> Processing Dependency: wbm-security-updates for package: virtualmin-base
–> Processing Dependency: wbm-php-pear for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-awstats for package: virtualmin-base
–> Processing Dependency: wbt-virtual-server-mobile for package: virtualmin-base
–> Processing Dependency: scponly for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-registrar for package: virtualmin-base
–> Processing Dependency: procmail-wrapper for package: virtualmin-base
–> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base
–> Processing Dependency: wbm-virtual-server for package: virtualmin-base
–> Processing Dependency: awstats for package: virtualmin-base
–> Processing Dependency: wbt-virtual-server-theme for package: virtualmin-base
–> Processing Dependency: ust-virtual-server-theme for package: virtualmin-base
—> Package awstats.noarch 0:6.8-1.el5 set to be updated
—> Package clamav.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
–> Processing Dependency: clamav-lib = 0.97.3-1.vm.el5.centos for package: clamav
–> Processing Dependency: data(clamav) for package: clamav
–> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: clamav
–> Processing Dependency: libclamav.so.6(CLAMAV_PRIVATE)(64bit) for package: clamav
–> Processing Dependency: libclamav.so.6()(64bit) for package: clamav
—> Package clamav-server.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
–> Processing Dependency: clamav-filesystem = 0.97.3-1.vm.el5.centos for package: clamav-server
–> Processing Dependency: init(clamav-server) for package: clamav-server
—> Package clamav-update.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
—> Package cyrus-sasl-md5.x86_64 0:2.1.22-7.el5_8.1 set to be updated
—> Package mod_fcgid.x86_64 0:2.2-1.el5.vm set to be updated
—> Package procmail-wrapper.x86_64 0:1.0-1.vm set to be updated
—> Package proftpd.x86_64 0:1.3.3c-1.el5.vm set to be updated
–> Processing Dependency: libGeoIP.so.1()(64bit) for package: proftpd
—> Package scponly.x86_64 0:4.6-1.vm set to be updated
—> Package usermin.noarch 0:1.510-1 set to be updated
—> Package ust-virtual-server-theme.noarch 2:6.9-1 set to be updated
—> Package wbm-php-pear.noarch 2:1.5-1 set to be updated
—> Package wbm-ruby-gems.noarch 2:1.4-1 set to be updated
—> Package wbm-security-updates.noarch 2:4.4-1 set to be updated
—> Package wbm-virtual-server.noarch 0:3.94.gpl-2 set to be updated
—> Package wbm-virtualmin-awstats.noarch 2:4.7-1 set to be updated
—> Package wbm-virtualmin-dav.noarch 2:3.5-1 set to be updated
—> Package wbm-virtualmin-htpasswd.noarch 2:2.6-1 set to be updated
—> Package wbm-virtualmin-init.noarch 2:2.3-1 set to be updated
—> Package wbm-virtualmin-mailman.noarch 2:6.1-2 set to be updated
—> Package wbm-virtualmin-registrar.noarch 2:2.1-1 set to be updated
—> Package wbm-virtualmin-svn.noarch 2:4.9-1 set to be updated
—> Package wbt-virtual-server-mobile.noarch 2:2.5-1 set to be updated
—> Package wbt-virtual-server-theme.noarch 2:8.5-2 set to be updated
—> Package webmin.noarch 0:1.590-1 set to be updated
—> Package GeoIP.x86_64 0:1.4.7-0.1.20090931cvs.el5 set to be updated
—> Package clamav-data.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
—> Package clamav-filesystem.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
–> Processing Dependency: fedora-usermgmt for package: clamav-filesystem
—> Package clamav-lib.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
—> Package clamav-server-sysv.x86_64 0:0.97.3-1.vm.el5.centos set to be updated
—> Package fedora-usermgmt.noarch 0:0.9-1.el5 set to be updated
–> Processing Dependency: fedora-usermgmt-core = 0.9-1.el5 for package: fedora-usermgmt
–> Processing Dependency: setup(fedora-usermgmt) for package: fedora-usermgmt
–> Processing Dependency: instance(fedora-usermgmt) for package: fedora-usermgmt
—> Package fedora-usermgmt-core.noarch 0:0.9-1.el5 set to be updated
—> Package fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5 set to be updated
—> Package fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5 set to be updated
Installing:
virtualmin-base noarch 1.0-61.rh virtualmin 27 k
GeoIP x86_64 1.4.7-0.1.20090931cvs.el5
virtualmin 710 k
awstats noarch 6.8-1.el5 virtualmin 1.2 M
clamav x86_64 0.97.3-1.vm.el5.centos virtualmin 943 k
clamav-data x86_64 0.97.3-1.vm.el5.centos virtualmin 30 M
clamav-filesystem x86_64 0.97.3-1.vm.el5.centos virtualmin 18 k
clamav-lib x86_64 0.97.3-1.vm.el5.centos virtualmin 4.4 M
clamav-server x86_64 0.97.3-1.vm.el5.centos virtualmin 98 k
clamav-server-sysv x86_64 0.97.3-1.vm.el5.centos virtualmin 18 k
clamav-update x86_64 0.97.3-1.vm.el5.centos virtualmin 88 k
cyrus-sasl-md5 x86_64 2.1.22-7.el5_8.1 updates 47 k
fedora-usermgmt noarch 0.9-1.el5 virtualmin 6.7 k
fedora-usermgmt-core noarch 0.9-1.el5 virtualmin 7.7 k
noarch 0.9-1.el5 virtualmin 6.6 k
noarch 0.9-1.el5 virtualmin 7.4 k
mod_fcgid x86_64 2.2-1.el5.vm virtualmin 124 k
procmail-wrapper x86_64 1.0-1.vm virtualmin 4.8 k
proftpd x86_64 1.3.3c-1.el5.vm virtualmin 3.5 M
scponly x86_64 4.6-1.vm virtualmin 24 k
usermin noarch 1.510-1 virtualmin-universal 6.1 M
noarch 2:6.9-1 virtualmin-universal 2.2 M
wbm-php-pear noarch 2:1.5-1 virtualmin-universal 14 k
wbm-ruby-gems noarch 2:1.4-1 virtualmin-universal 14 k
wbm-security-updates noarch 2:4.4-1 virtualmin-universal 32 k
wbm-virtual-server noarch 3.94.gpl-2 virtualmin-universal 1.9 M
noarch 2:4.7-1 virtualmin-universal 41 k
wbm-virtualmin-dav noarch 2:3.5-1 virtualmin-universal 24 k
noarch 2:2.6-1 virtualmin-universal 20 k
wbm-virtualmin-init noarch 2:2.3-1 virtualmin-universal 23 k
noarch 2:6.1-2 virtualmin-universal 42 k
noarch 2:2.1-1 virtualmin-universal 69 k
wbm-virtualmin-svn noarch 2:4.9-1 virtualmin-universal 45 k
noarch 2:2.5-1 virtualmin-universal 72 k
noarch 2:8.5-2 virtualmin-universal 2.2 M
webmin noarch 1.590-1 virtualmin-universal 18 M
Transaction Summary
Install 35 Package(s)
Upgrade 0 Package(s)
Total download size: 72 M
Total 245 kB/s | 72 MB 04:59
Running Transaction
Installing : cyrus-sasl-md5 1/35
Installing : mod_fcgid 2/35
Installing : procmail-wrapper 3/35
Installing : GeoIP 4/35
Installing : webmin 5/35Webmin install complete. You can now login to https://ocean.hilgfz.com:32767/
as root with your root password.
Installing : wbm-virtual-server 6/35virtual-server
Operating system is CentOS Linux
Installing : usermin 7/35Usermin install complete. You can now login to https://ocean.hilgfz.com:20000/
as any user on your system.
Installing : proftpd 8/35
Installing : ust-virtual-server-theme 9/35
Installing : wbm-virtualmin-svn 10/35virtualmin-svn
Installing : wbm-virtualmin-dav 11/35virtualmin-dav
Installing : wbt-virtual-server-theme 12/35
Installing : wbm-virtualmin-awstats 13/35virtualmin-awstats
Installing : wbt-virtual-server-mobile 14/35
Installing : wbm-virtualmin-registrar 15/35virtualmin-registrar
Installing : wbm-virtualmin-init 16/35virtualmin-init
Installing : wbm-ruby-gems 17/35ruby-gems
Installing : wbm-virtualmin-htpasswd 18/35virtualmin-htpasswd
Installing : wbm-php-pear 19/35php-pear
Installing : wbm-security-updates 20/35security-updates
Installing : wbm-virtualmin-mailman 21/35virtualmin-mailman
Installing : awstats 22/35
Installing : scponly 23/35
Installing : fedora-usermgmt-default-fedora-setup 24/35
Installing : fedora-usermgmt-core 25/35
Installing : fedora-usermgmt-shadow-utils 26/35
Installing : fedora-usermgmt 27/35
Installing : clamav-filesystem 28/35
Installing : clamav-data 29/35
Installing : clamav-lib 30/35
Installing : clamav 31/35
Installing : clamav-update 32/35
Installing : clamav-server 33/35
Installing : virtualmin-base 34/35Setting Webmin theme
Setting Usermin theme
Error occurred while setting Usermin theme: Failed to open PID file at …/web-lib-funcs.pl line 1360.
Configuring Postfix
Enabling Postfix and disabling Sendmail
Setting up freshclam
ClamAV update process started at Fri Sep 28 18:10:23 2012
DON’T PANIC! Read http://www.clamav.net/support/faq
main.cvd is up to date (version: 54, sigs: 1044387, f-level: 60, builder: sven)
nonblock_connect: connect timing out (30 secs)
Can’t connect to port 80 of host database.clamav.net (IP: 211.239.150.206)
Trying host database.clamav.net (120.29.176.126)…
Downloading daily.cvd [ 0%]
Downloading daily.cvd [100%]
daily.cvd updated (version: 15411, sigs: 268521, f-level: 63, builder: jesler)
Downloading bytecode.cvd [ 7%]
Downloading bytecode.cvd [100%]
bytecode.cvd updated (version: 190, sigs: 36, f-level: 63, builder: neo)
Database updated (1312944 signatures) from database.clamav.net (IP: 27.96.54.66)
Configuring Dovecot for POP3 and IMAP
Error occurred while configuring or enabling Dovecot: flush_file_lines called on non-loaded file /etc/dovecot/dovecot.conf /etc/dovecot.conf at web-lib-funcs.pl line 1360.
Enabling ProFTPd
鍚姩 proftpd锛歔纭畾]
Enabling SMTP authentication
鍚姩 saslauthd锛歔纭畾]
Configuring Virtualmin
Configuring Procmail
Configuring Webalizer
Updating /etc/shells
Enabling MySQL and PostgreSQL
Enabling Apache
Configuring and enabling BIND
Configuring resolv.conf to use local DNS server
Configuring and enabling Mailman
Enabling status monitoring
Hiding the Webmin upgrade page
Error occurred hiding Webmin upgrade page:
convertquota: Quota file not found or has wrong format.
convertquota: Can’t open old format file for users on /
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, signal 2
FATAL - 2012-09-28 18:12:18 - Fatal Error Occurred: Installation failed: 0
FATAL - 2012-09-28 18:12:18 - Cannot continue installation.
FATAL - 2012-09-28 18:12:18 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-09-28 18:12:18 - re-attempted after any problems have been resolved.
FATAL - 2012-09-28 18:12:18 - Removing temporary directory and files.
FATAL - 2012-09-28 18:12:18 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-09-28 18:12:18 - in /root/virtualmin-install.log
INFO - 2012-09-28 20:51:51 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 20:51:51 - Install mode: full
DEBUG - 2012-09-28 20:51:51 - Product: Virtualmin GPL
DEBUG - 2012-09-28 20:51:51 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 20:51:52 - install.sh version: 1.0.9
INFO - 2012-09-28 20:51:52 - Checking for fully qualified hostname…
INFO - 2012-09-28 20:51:52 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 20:51:52 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 20:51:52 - Loading OS selection library…
INFO - 2012-09-28 20:51:52 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 20:51:52 - Loading OS list…
INFO - 2012-09-28 20:51:53 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 20:51:53 - Operating system name: CentOS Linux
INFO - 2012-09-28 20:51:53 - Operating system version: 5
INFO - 2012-09-28 20:51:53 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 20:51:53 - Disabling SELinux during installation…
INFO - 2012-09-28 20:51:53 - setenforce 0 failed: 1
INFO - 2012-09-28 20:51:54 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2012-09-28 20:51:55 - Succeeded.
INFO - 2012-09-28 20:51:55 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Package 30:bind-9.3.6-20.P1.el5_8.4.x86_64 already installed and latest version
Package 30:bind-utils-9.3.6-20.P1.el5_8.4.x86_64 already installed and latest version
Package 30:caching-nameserver-9.3.6-20.P1.el5_8.4.x86_64 already installed and latest version
Package 1:httpd-2.2.3-63.1.vm.x86_64 already installed and latest version
Package 2:postfix-2.3.3-2.3.el5_6.x86_64 already installed and latest version
Package spamassassin-3.3.1-2.el5.x86_64 already installed and latest version
Package perl-DBD-Pg-1.49-4.el5_8.x86_64 already installed and latest version
Package perl-DBD-MySQL-3.0007-2.el5.x86_64 already installed and latest version
Package python-2.4.3-46.el5_8.2.x86_64 already installed and latest version
Package 3:mailman-2.1.9-6.el5_6.1.x86_64 already installed and latest version
Package subversion-1.6.11-10.el5_8.x86_64 already installed and latest version
Package subversion-1.6.11-10.el5_8.i386 already installed and latest version
Package mysql-5.0.95-1.el5_7.1.x86_64 already installed and latest version
Package mysql-5.0.95-1.el5_7.1.i386 already installed and latest version
Package mysql-server-5.0.95-1.el5_7.1.x86_64 already installed and latest version
Package mysql-devel-5.0.95-1.el5_7.1.x86_64 already installed and latest version
Package mysql-devel-5.0.95-1.el5_7.1.i386 already installed and latest version
Package postgresql-8.1.23-6.el5_8.x86_64 already installed and latest version
Package postgresql-server-8.1.23-6.el5_8.x86_64 already installed and latest version
Package webalizer-2.01_10-30.1.x86_64 already installed and latest version
Package php-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-xml-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-gd-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-imap-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-mysql-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-odbc-5.1.6-39.el5_8.x86_64 already installed and latest version
Package 1:php-pear-1.4.9-8.el5.noarch already installed and latest version
Package php-pgsql-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-snmp-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-xmlrpc-5.1.6-39.el5_8.x86_64 already installed and latest version
Package php-mbstring-5.1.6-39.el5_8.x86_64 already installed and latest version
Package mod_perl-2.0.4-6.el5.x86_64 already installed and latest version
Package mod_python-3.2.8-3.1.x86_64 already installed and latest version
Package cyrus-sasl-2.1.22-7.el5_8.1.x86_64 already installed and latest version
Package cyrus-sasl-2.1.22-7.el5_8.1.i386 already installed and latest version
Package dovecot-1.0.7-7.el5_7.1.x86_64 already installed and latest version
Package mod_dav_svn-1.6.11-10.el5_8.x86_64 already installed and latest version
Package cyrus-sasl-gssapi-2.1.22-7.el5_8.1.x86_64 already installed and latest version
Package cyrus-sasl-gssapi-2.1.22-7.el5_8.1.i386 already installed and latest version
Package 2:mod_ssl-2.2.3-63.1.vm.x86_64 already installed and latest version
Package ruby-1.8.5-24.el5.x86_64 already installed and latest version
Package ruby-devel-1.8.5-24.el5.x86_64 already installed and latest version
Package ruby-devel-1.8.5-24.el5.i386 already installed and latest version
Package rubygems-0.9.2-1.el5.noarch already installed and latest version
Package perl-XML-Simple-2.14-4.fc6.noarch already installed and latest version
Package perl-Crypt-SSLeay-0.51-11.el5.x86_64 already installed and latest version
Nothing to do
INFO - 2012-09-28 20:52:03 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 20:52:03 - Succeeded.
INFO - 2012-09-28 20:52:03 - Installing Virtualmin and all related packages now using the command:
INFO - 2012-09-28 20:52:03 - yum clean all
INFO - 2012-09-28 20:52:03 - yum -y -d 2 install virtualmin-base
Package virtualmin-base-1.0-61.rh.noarch already installed and latest version
Nothing to do
INFO - 2012-09-28 20:52:23 - yum -y -d 2 install virtualmin-base: Succeeded.
INFO - 2012-09-28 20:52:23 - Checking for updates to Virtualmin-related packages…
Nothing to do
INFO - 2012-09-28 20:52:30 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 20:52:30 - Updating SpamAssassin rules…
INFO - 2012-09-28 20:52:40 - Rule updates done
INFO - 2012-09-28 21:09:02 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 21:09:02 - Install mode: full
DEBUG - 2012-09-28 21:09:02 - Product: Virtualmin GPL
DEBUG - 2012-09-28 21:09:02 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 21:09:02 - install.sh version: 1.0.9
INFO - 2012-09-28 21:09:02 - Checking for fully qualified hostname…
INFO - 2012-09-28 21:09:02 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 21:09:02 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 21:09:02 - Loading OS selection library…
INFO - 2012-09-28 21:09:03 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 21:09:03 - Loading OS list…
INFO - 2012-09-28 21:09:03 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 21:09:04 - Operating system name: CentOS Linux
INFO - 2012-09-28 21:09:04 - Operating system version: 5
INFO - 2012-09-28 21:09:04 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 21:09:04 - Disabling SELinux during installation…
INFO - 2012-09-28 21:09:04 - setenforce 0 failed: 1
INFO - 2012-09-28 21:09:05 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
FATAL - 2012-09-28 21:09:05 - Fatal Error Occurred: Installation of virtualmin-release failed: 1
FATAL - 2012-09-28 21:09:05 - Cannot continue installation.
FATAL - 2012-09-28 21:09:05 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-09-28 21:09:05 - re-attempted after any problems have been resolved.
FATAL - 2012-09-28 21:09:05 - Removing temporary directory and files.
FATAL - 2012-09-28 21:09:05 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-09-28 21:09:05 - in /root/virtualmin-install.log
INFO - 2012-09-28 21:19:41 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 21:19:41 - Install mode: full
DEBUG - 2012-09-28 21:19:41 - Product: Virtualmin GPL
DEBUG - 2012-09-28 21:19:41 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 21:19:41 - install.sh version: 1.0.9
INFO - 2012-09-28 21:19:41 - Checking for fully qualified hostname…
INFO - 2012-09-28 21:19:41 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 21:19:41 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 21:19:41 - Loading OS selection library…
INFO - 2012-09-28 21:19:41 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 21:19:41 - Loading OS list…
INFO - 2012-09-28 21:19:42 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 21:19:42 - Operating system name: CentOS Linux
INFO - 2012-09-28 21:19:42 - Operating system version: 5
INFO - 2012-09-28 21:19:42 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 21:19:42 - Disabling SELinux during installation…
INFO - 2012-09-28 21:19:42 - setenforce 0 failed: 1
INFO - 2012-09-28 21:19:43 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2012-09-28 21:19:51 - Succeeded.
INFO - 2012-09-28 21:19:51 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Nothing to do
INFO - 2012-09-28 21:19:58 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 21:19:58 - Succeeded.
INFO - 2012-09-28 21:19:58 - Installing Virtualmin and all related packages now using the command:
INFO - 2012-09-28 21:19:58 - yum clean all
INFO - 2012-09-28 21:19:59 - yum -y -d 2 install virtualmin-base
- base: ftp.neowiz.com
- extras: mirror.yongbok.net
- updates: mirrors.ta139.com
Nothing to do
INFO - 2012-09-28 21:21:01 - yum -y -d 2 install virtualmin-base: Succeeded.
INFO - 2012-09-28 21:21:01 - Checking for updates to Virtualmin-related packages…
Nothing to do
INFO - 2012-09-28 21:21:07 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 21:21:07 - Updating SpamAssassin rules…
INFO - 2012-09-28 21:21:09 - Rule updates done
INFO - 2012-09-28 21:31:31 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 21:31:31 - Install mode: full
DEBUG - 2012-09-28 21:31:31 - Product: Virtualmin GPL
DEBUG - 2012-09-28 21:31:31 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 21:31:31 - install.sh version: 1.0.9
INFO - 2012-09-28 21:31:31 - Checking for fully qualified hostname…
INFO - 2012-09-28 21:31:31 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 21:31:31 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 21:31:31 - Loading OS selection library…
INFO - 2012-09-28 21:31:32 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 21:31:32 - Loading OS list…
INFO - 2012-09-28 21:31:33 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 21:31:33 - Operating system name: CentOS Linux
INFO - 2012-09-28 21:31:33 - Operating system version: 5
INFO - 2012-09-28 21:31:33 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 21:31:33 - Disabling SELinux during installation…
INFO - 2012-09-28 21:31:33 - setenforce 0 failed: 1
INFO - 2012-09-28 21:31:34 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
FATAL - 2012-09-28 21:31:34 - Fatal Error Occurred: Installation of virtualmin-release failed: 1
FATAL - 2012-09-28 21:31:34 - Cannot continue installation.
FATAL - 2012-09-28 21:31:34 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-09-28 21:31:34 - re-attempted after any problems have been resolved.
FATAL - 2012-09-28 21:31:34 - Removing temporary directory and files.
FATAL - 2012-09-28 21:31:34 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-09-28 21:31:34 - in /root/virtualmin-install.log
INFO - 2012-09-28 21:32:20 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 21:32:20 - Install mode: full
DEBUG - 2012-09-28 21:32:20 - Product: Virtualmin GPL
DEBUG - 2012-09-28 21:32:20 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 21:32:20 - install.sh version: 1.0.9
INFO - 2012-09-28 21:32:20 - Checking for fully qualified hostname…
INFO - 2012-09-28 21:32:20 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 21:32:20 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 21:32:20 - Loading OS selection library…
INFO - 2012-09-28 21:32:20 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 21:32:20 - Loading OS list…
INFO - 2012-09-28 21:32:21 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 21:32:21 - Operating system name: CentOS Linux
INFO - 2012-09-28 21:32:21 - Operating system version: 5
INFO - 2012-09-28 21:32:21 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 21:32:21 - Disabling SELinux during installation…
INFO - 2012-09-28 21:32:21 - setenforce 0 failed: 1
INFO - 2012-09-28 21:32:22 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2012-09-28 21:32:23 - Succeeded.
INFO - 2012-09-28 21:32:23 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Nothing to do
INFO - 2012-09-28 21:32:29 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 21:32:29 - Succeeded.
INFO - 2012-09-28 21:32:29 - Installing Virtualmin and all related packages now using the command:
INFO - 2012-09-28 21:32:29 - yum clean all
INFO - 2012-09-28 21:32:30 - yum -y -d 2 install virtualmin-base
- base: mirror.bit.edu.cn
- extras: www.ftp.ne.jp
- updates: mirror.bit.edu.cn
Nothing to do
INFO - 2012-09-28 21:33:03 - yum -y -d 2 install virtualmin-base: Succeeded.
INFO - 2012-09-28 21:33:03 - Checking for updates to Virtualmin-related packages…
Nothing to do
INFO - 2012-09-28 21:33:09 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2012-09-28 21:33:09 - Updating SpamAssassin rules…
INFO - 2012-09-28 21:33:09 - Rule updates done
INFO - 2012-09-28 21:37:34 - Started installation log in /root/virtualmin-install.log
DEBUG - 2012-09-28 21:37:34 - Install mode: full
DEBUG - 2012-09-28 21:37:34 - Product: Virtualmin GPL
DEBUG - 2012-09-28 21:37:34 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2012-09-28 21:37:34 - install.sh version: 1.0.9
INFO - 2012-09-28 21:37:34 - Checking for fully qualified hostname…
INFO - 2012-09-28 21:37:34 - Hostname OK: fully qualified as ocean.hilgfz.com
INFO - 2012-09-28 21:37:34 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2012-09-28 21:37:34 - Loading OS selection library…
INFO - 2012-09-28 21:37:35 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2012-09-28 21:37:35 - Loading OS list…
INFO - 2012-09-28 21:37:35 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2012-09-28 21:37:36 - Operating system name: CentOS Linux
INFO - 2012-09-28 21:37:36 - Operating system version: 5
INFO - 2012-09-28 21:37:36 - Configuring package manager for CentOS Linux 5…
INFO - 2012-09-28 21:37:36 - Disabling SELinux during installation…
INFO - 2012-09-28 21:37:36 - setenforce 0 failed: 1
INFO - 2012-09-28 21:37:37 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
FATAL - 2012-09-28 21:37:37 - Fatal Error Occurred: Installation of virtualmin-release failed: 1
FATAL - 2012-09-28 21:37:37 - Cannot continue installation.
FATAL - 2012-09-28 21:37:37 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2012-09-28 21:37:37 - re-attempted after any problems have been resolved.
FATAL - 2012-09-28 21:37:37 - Removing temporary directory and files.
FATAL - 2012-09-28 21:37:37 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2012-09-28 21:37:37 - in /root/virtualmin-install.log
