I’m quite new to Virtualmin and my university wishes to test it and possibly use it for future web degrees.
I’ve installed Debian 4 on my PC as standard with no extras just the GUI and so on… I’ve ran the Install.sh as stated in the Installation guide but it stops at “Running newaliases”. I’ve attached the record of install, can anyone tell me what I might be doing wrong or missed ?? As stated…it’s a fresh install with no extras and updates ?
"Running newaliases
|Stopping Postfix Mail Transport Agent: postfix.
Starting Postfix Mail Transport Agent: postfi-.
INFO - ...in progress, please wait... Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command:
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
it seems to just sit and do nothing at this point ???
If you have enabled CD-based repositories on your system, it may be hung waiting for you to insert a CD. Disable that kind of repo, and all will be well. We try to disable them…but something broke a couple of revisions back, and I haven’t fixed it yet.
