Howdy all,
I’ve rolled out version 7.2 of the Virtualmin virtual-server module.
Changes:
- Add significant improvements to CloudFlare DNS support including proxying and importing existing zones
- Add multiple FPM improvements in #425
- Add .well-known location work with proxy enabled sites in #422
- Add repos check and throw an error if outdated in #434
- Add an API command to mass update IPs in b239113
- Add DKIM DNS record check and split up table showing DKIM keys
- Add various DNS related improvements
- Fix support for WHMCS 8.5.x automatic post-install and upgrades
- Fix to default to PHP-FPM on new installs
- Fix to drop adding no longer needed
<Proxy *>
directives in #423 - Fix to use Require all granted directives with Apache 2.4 in #424
- Fix to remove download immediately option in #379
- Fix to make sure that actual PHP version is set by the script in #437
- Fix PHP max children logic in #439
- Fix upgrades to Pro work correctly for both Virtualmin 6 and 7 installs
- Fix to turn off autoconfig when email is disabled for a domain #408
- Fix to use correct field for DNS slave servers
- Fix to include Virtualmin Pro API commands in
virtualmin --help
output
As always, let us know about any problems (in a new topic).
Cheers,
Joe
