I’m testing new vps system provided by scaleway.com with debian jessie.
When I launch the installation script, I have an error:
INFO - 2016-04-18 15:29:47 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-04-18 15:29:47 - Install mode: full
DEBUG - 2016-04-18 15:29:47 - Product: Virtualmin GPL
DEBUG - 2016-04-18 15:29:47 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-04-18 15:29:47 - install.sh version: 1.1.2
INFO - 2016-04-18 15:29:47 - Checking for fully qualified hostname…
INFO - 2016-04-18 15:29:47 - Hostname OK: fully qualified as ip6-allrouters10.1.48.158
INFO - 2016-04-18 15:29:47 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-04-18 15:29:47 - Loading OS selection library…
INFO - 2016-04-18 15:29:47 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-04-18 15:29:47 - Loading OS list…
INFO - 2016-04-18 15:29:48 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-04-18 15:29:48 - Operating system name: Debian Linux
INFO - 2016-04-18 15:29:48 - Operating system version: 8
INFO - 2016-04-18 15:29:48 - Configuring package manager for Debian Linux 8…
INFO - 2016-04-18 15:29:48 - Enabling universe repositories, if not already available…
INFO - 2016-04-18 15:29:48 - Disabling cdrom repositories…
INFO - 2016-04-18 15:30:12 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2016-04-18 15:30:12 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2016-04-18 15:30:12 - Installing Webmin and Virtualmin package signing keys…
INFO - 2016-04-18 15:30:13 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2016-04-18 15:30:13 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2016-04-18 15:30:14 - OK
INFO - 2016-04-18 15:30:15 - OK
INFO - 2016-04-18 15:30:28 - Ign
INFO - 2016-04-18 15:30:28 - Removing Debian standard Webmin package, if they exist…
INFO - 2016-04-18 15:30:28 - Removing Debian apache packages…
DEBUG - 2016-04-18 15:30:39 - Reading
INFO - 2016-04-18 15:30:39 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install bsdutils postfix postfix-pcre webmin usermin ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail procmail-wrapper libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libapache2-mod-php5 php5-mysql
Reading package lists…
Building dependency tree…
Reading state information…
FATAL - 2016-04-18 15:30:42 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2016-04-18 15:30:42 - Cannot continue installation.
FATAL - 2016-04-18 15:30:42 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-04-18 15:30:42 - re-attempted after any problems have been resolved.
FATAL - 2016-04-18 15:30:42 - Removing temporary directory and files.
FATAL - 2016-04-18 15:30:42 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-04-18 15:30:42 - in /root/virtualmin-install.log
There is no information about the error.
I did’nt install anything before, just done apt-get update.
Other infos:
root@host:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.3 (jessie)
Release: 8.3
Codename: jessie
What can I do?
