Hi there,
Yesterday I installed a Virtualmin on a CentOS 6.2 without any issues.
Today I wanted to install it on an identical system, but keep getting fatal errors:
warning: rpmts_HdrFromFdno: Header V3 RSA/SHA256 Signature, key ID 0608b895: NOKEY
The GPG keys listed for the “Red Hat Enterprise 6 - x86_64 - Virtualmin” repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository. yum -y -d 2 install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
wbm-virtualmin-svn noarch 2:4.9-1 virtualmin-universal 45 k
wbt-virtual-server-mobile noarch 2:2.4-1 virtualmin-universal 71 k
wbt-virtual-server-theme noarch 2:8.4-1 virtualmin-universal 2.2 M
webmin noarch 1.585-1 virtualmin-universal 16 M
Transaction Summary
Install 30 Package(s)
Total download size: 75 M
Installed size: 126 M
Downloading Packages:
Total 2.1 MB/s | 75 MB 00:34
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-virtualmin
FATAL - Fatal Error Occurred: Installation failed: 0
Any idea why this is happening all of a sudden?
Any help is appreciated, thanks!
Patrick
