Hi Everybody,
Today i tried to reinstall Virtualmin because i got a hard drive chrash today on my Debian 5.04 server, but when i run install.sh i got this error
INFO - 2010-05-01 20:30:21 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip postfix-tls
Reading package lists...
Building dependency tree...
Reading state information...
postfix is already the newest version.
unzip is already the newest version.
Package postfix-tls is a virtual package provided by:
postfix 2.5.5-1.1
You should explicitly select one to install.
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
I tried installing postfix using apt-get install postfix, but then didnt fix anything (just for the record, postfix-tls is a virtual package for either postfix 2.5.5 or 2.3.8)
So anybody who can help me figure this one out ?
