I am using Debian 8 with Intel xeion server with 32 GB RAM and with 240 GB SSD Intel 1200 series Mother Board, I installed Virtualmin with no errors on this server, but due to SSH server installation after the Vertualmin the BIND server stops and also SSH Stops, as I unable to start the servers by Web Gui as well as with command also, I tried to start new installation Debian 8 minimal with SSH server only, and after the debian 8 installation complete I tried with this command to install the virtualmin as I did before and I am getting this error
Command I used to install Virtualmin
root@debian# wget http://software.virtualmin.com/gpl/scripts/install.sh
root@debian# sh ./install.sh -b LEMP
and I am getting this error at the time of webmin installatin
Phase 2 of 3: Installation
Installing Webmin [ERROR] Failed with error: 100
[ERROR] Something went wrong. Exiting.
[ERROR] The last few log entries were:
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
webmin : Depends: libauthen-pam-perl but it is not installable
Depends: libio-pty-perl but it is not installable
Depends: apt-show-versions but it is not installable
E: Unable to correct problems, you have held broken packages.
Installing Webmin: [2017-11-17 17:27:02 IST] [ERROR] Failed with error: 100
[2017-11-17 17:27:02 IST] [ERROR] Something went wrong. Exiting.
[2017-11-17 17:27:02 IST] [ERROR] The last few log entries were:
root@debian#
Please any one to help me out… I tried to install Debian 8 freshly with virtualmin also freshly.
