Virtualmin Installation Fail in Centos 5.5
I followed the instuctions of http://www.virtualmin.com/documentation/id,centos_5_install
but after finishing the installation script I receive.
Configuring Dovecot for POP3 and IMAP
Enabling Dovecot POP3 and IMAP servers
Enabling ProFTPd
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, signal 9
Installing : clamav-server-sysv 35/35
Installed:
virtualmin-base.noarch 0:1.0-61.rh
Dependency Installed:
GeoIP.x86_64 0:1.4.7-0.1.20090931cvs.el5
awstats.noarch 0:6.8-1.el5
clamav.x86_64 0:0.96.5-1.vm.el5
clamav-data.x86_64 0:0.96.5-1.vm.el5
clamav-filesystem.x86_64 0:0.96.5-1.vm.el5
clamav-lib.x86_64 0:0.96.5-1.vm.el5
clamav-server.x86_64 0:0.96.5-1.vm.el5
clamav-server-sysv.x86_64 0:0.96.5-1.vm.el5
clamav-update.x86_64 0:0.96.5-1.vm.el5
cyrus-sasl-md5.x86_64 0:2.1.22-5.el5_4.3
fedora-usermgmt.noarch 0:0.9-1.el5
fedora-usermgmt-core.noarch 0:0.9-1.el5
fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5
fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5
mod_fcgid.x86_64 0:2.2-1.el5.vm
procmail-wrapper.x86_64 0:1.0-1.vm
proftpd.x86_64 0:1.3.3c-1.el5.vm
scponly.x86_64 0:4.6-1.vm
usermin.noarch 0:1.460-1
ust-virtual-server-theme.noarch 2:6.9-1
wbm-php-pear.noarch 2:1.5-1
wbm-ruby-gems.noarch 2:1.4-1
wbm-security-updates.noarch 2:4.0-1
wbm-virtual-server.noarch 0:3.83.gpl-1
wbm-virtualmin-awstats.noarch 2:4.4-1
wbm-virtualmin-dav.noarch 2:3.3-1
wbm-virtualmin-htpasswd.noarch 2:2.3-1
wbm-virtualmin-init.noarch 2:2.1-1
wbm-virtualmin-mailman.noarch 2:5.9-1
wbm-virtualmin-registrar.noarch 2:2.0-1
wbm-virtualmin-svn.noarch 2:4.7-1
wbt-virtual-server-mobile.noarch 2:2.3-1
wbt-virtual-server-theme.noarch 2:7.8-1
webmin.noarch 0:1.530-1
Complete!
FATAL - 2011-02-04 18:17:07 - Fatal Error Occurred: Installation failed: 0
FATAL - 2011-02-04 18:17:07 - Cannot continue installation.
FATAL - 2011-02-04 18:17:07 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2011-02-04 18:17:08 - re-attempted after any problems have been resolved.
FATAL - 2011-02-04 18:17:24 - Removing temporary directory and files.
FATAL - 2011-02-04 18:17:24 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2011-02-04 18:17:25 - in /root/virtualmin-install.log
How much memory do you have? I think it is memory related.
256 MB
Yes, 256BM is very tight :slight_smile:
and to be a bit more constructive :slight_smile:
http://www.virtualmin.com/documentation/system/low-memory
Ok and How Much memory I need to make the installation Work ?
The document/link I posted indicates that it might be possible to install virtualmin with 256MB if you follow the steps listed.
I personally never had any issue installing virtualmin on a 512MB Centos 5.5 system. However 512MB might be still tight if you plan to run apache, BIND, Dovecot, mysql, spamass., clamav, proftpd and postfix. Especially if you are on OpenVZ vps, because there is not swap space and services will crash in low memory situations.
But 512MB might be still ok for low traffic sites.
