I changed my VPS from ispconfig to virtualmin because of issues with the old installation. But now it looks like the email virusscanner is not working at all
Spam and Virusfiltering are enabled for all domains.
The status of your system is being checked to ensure that all enabled features are available, that the mail server is properly configured, and that quotas are active ..
Your system has 3.94 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the Postfix Mailserver module.
Apache is installed.
The following PHP versions are available : 5.3.10 (/usr/bin/php5-cgi)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and assumed to be running.
Plugin AWstats reporting is installed OK.
Plugin Mailman is installed OK.
Plugin Protected web directories is installed OK.
Using network interface eth0 for virtual IPs.
IPv6 addresses are available, using interface eth0.
Default IP address for virtual servers is xx.xx.xx.205.
Default IP address is set to xx.xx.xx.205, which matches the detected external address.
Both user and group quotas are enabled for home and email directories.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
.. your system is ready for use by Virtualmin.
When i change it back it still seem to be working. However after i just installed virtualmin the virusses seem to pass the mailserver without issue. Why is there no rule about the virusscanner in the mail header (just to see it has scanned the mail without issues)
