A few weeks ago I bought a new server, because I want to use this one to host about 15 domains for me and friends I was checking all kinds of hosting control panels to find one that will fit for what I want to do.
I checked out Plesk, DirectAdmin, ISP Config, CubePanel etc., they all look nice, but all these panels are not all THAT.
Then I found Virtualmin/Webmin…I already knew Webmin for years but knew that there were several bugs in the past.
But after checking out several reviews etc. it looked very promising so decided to install it.
First impression was perfect. When you never have any experience with Virtualmin you absolutely need 1-2 days to figure out everything, where do I change this, where do I change that etc., but after a week I know exactly what to change and where to change it
But now my question (finally ),
I use the combo of Dovecot and Postfix and have setup Procmail via the Virtualmin Webinterface to use Spamassassin for checking incoming mails for spam.
But how can I also use ClamAv to check all incoming emails for virusses?
ClamAV is installed (yum -y install clamav* returns that everything is installed and up-to-date).
So what needs to be done to use Postfix and Dovecot and also Spamassassin and ClamAV?
To enable clam, you’ll first want to setup clamd. This is really ugly in the stock packages for most platforms, and it is different depending on the OS and version (you haven’t told us that information, so I can’t get specific)…but you only have to do it once.
Once clamd is running, add a new test to your procmail configuration, something like this:
:0
VIRUS=|clamdscan --disable-summary --stdout -
:0fw
VIRUS ?? ^.: /. FOUND
/dev/null
The /dev/null is delivering the mail to nowhere (i.e. deleting it).
:0
:0fw
/dev/null
