I have a problem with the Virtualmin Git Repositories 1.0 it does not support smart http. And my Eclipse eGit is using smart http. Does anybody know how to fix this?
Currently virtualmin’s git plugin doesn’t support smart git, but you could probably manually setup support for it by copying git-http-backend
to the domain’s cgi-bin
directory. You’d then need to adjust the Apache configuration to use this for the /git
URL path, as documented on http://progit.org/2010/03/04/smart-http.html
Hmm when i try to do that I get a new error, I did try the documentation but it does not seem that its working.
Can’t connect to any URI: http://SOMEUSER@SOMSITE/git/SOMEGIT.git (Push service is not available: http://SOMEUSER@SOMSITE/git/SOMEGIT.git: http://SOMEUSER@SOMSITE/git/SOMEGIT.git/info/refs?service=git-receive-pack not found)
If i copy the git-receive-pack over to the local CGI-BIN folder it does not work either. I then try to add this because of the gitweb
ScriptAliasMatch
“(?x)^/git/(.*/(HEAD |
info/refs |
objects/(info/[^/]+ |
[0-9a-f]{2}/[0-9a-f]{38} |
pack/pack-[0-9a-f]{40}.(pack|idx)) |
git-(upload|receive)-pack))$”
/home/SOMESITE/cgi-bin/git-http-backend/$1
ScriptAlias /git/ /home/SOMESITE/public_html/git/gitweb.cgi/
But that does not do anything.
I am pretty lost in this.
