Virtualmin duplicating hostname A records (possible bug)
OS type and version RL9
Webmin version 2.111
Virtualmin version 7.10.0
In virtualmin > server templates > default > dns domain I have ns1/ns2 nameservers in Additional manually configured nameservers and then in Primary DNS server hostname I have another (the hostname for my machine, eg, servername.mydomain.tld) however when I create a new Virtualmin account, then go to virtualmin > DNS records I noticed that virtualmin has created two identical A - IPv4 Address records for the hostname (servername.mydomain.tld) as well as for the AAAA - IPv6 Address hostname.
Seems like a bug? I have pretty much the same set-up on an identical (recent) virtualmin install (but on RL8) and it only creates one hostname record for ipv4 and ipv4 A records.
Oh that’s weird, when I delete one of them… they both disappear! :scream:
(Edit: creating them manually and I am left with just one of each.)
On the virtualmin 7.20 I believe there might of been some fixes to nameservers and templates.
So your creating a virtual server with the same name as the hostname of the server ( you should not do that) or you just created a A record for it, just to be clear.
Never seen a post with 2 * A records and 2 * AAAA records being created, can you create a screenshot showing the issue.
I don’t have IP6 enable so this is what I get created with a new virtual server
Actually just checked on another server and it’s the same there.
I am guessing it only does this for the first domain then - the one that is to act as the nameservers for that server (and which includes the hostname for that server such as servername.mymaindomain.tld).
No… the virtualmin account is for mymaindomain.tld - but the hostname for the server is servername.mymaindomain.tld
It’s literally just two identical records which also show when you go to ‘manually edit records’, here’s a snippet:
servername.domain.tld.	IN	A	33.44.55.66
servername.domain.tld.	IN	AAAA	3a01:5f9:14a:7c4::4
So your creating a subserver or top level.
Top-level server (I pretty much always create top-level servers)
No I can’t replicate that issue, I create another top level called server.example.com and still no two A record being created. Check your template and see if you can see anything in there.
default is no extra records
maybe this setting may create a extra A
Nope it creates ns1.example.com A records.
It works fine for subsequent accounts, it just appears to happen for the first account which is also happens to be the main nameserver/hostname domain for that server. (The hostname for every server I set up is usually something like someservername.serverdomain.tld - which then acts as the nameserver for all other domains, eg ns1.serverdomain.tld.)
(My server templates are the same as yours Stefan)
Right, I’d have a create a new server and test.
Tried on new install, still can’t replicate sorry.
Never heard of such a thing. Seems like you must be doing something unusual, but I have no idea what.
Have you customized the DNS in Server Templates?
@Jamie, wasn’t that one of the DNS related bugs you had already fixed for the upcoming Virtualmin 7.20, or is it something else?
The issue Jamie worked on is duplicate and/or erroneous IPs added to named.conf. I hadn’t reported any issues with the zone files. I could be wrong but I believe he fixed it. I’ll be able to confirm once the next version of Webmin and Virtualmin 7.20 are released.
I don’t think I fixed this one.
@Brook can you attach a screenshot of the DNS server template page?
Here ya go Jamie - I usually set it up like the first image, but sometimes do what’s in the second image (the problem persists on both - which to clarify is just on the creation of the first account, works as expected after that):
Some other things that might help:
I set up FQDN/hostname via:
/etc/sysconfig/network
/etc/hosts
/etc/hostname
reboot
Usually giving it a memorable hostname, for example sunshine.mydomain.tld.
mydomain.tld is then set to act as the nameservers for all domains on that server, and I usually configure three nameservers:
ns1.mydomain.tld
ns2.mydomain.tld
As per my notes, I…
Virtualmin > System Settings > Server Templates > Default Settings
  • DNS domain > Primary DNS server hostname > instead of Automatic choose Hostname and fill in your primary NS record: eg ns1.domain.tld or sunshine.mydomain.tld
  • While there:
    • Address records for new domains > Domain name ✓ www.domain ✓
    • Does SPF record cover all senders? > Yes, and deny other senders/Action for other senders: Dissalow
    • Additional manually configured nameservers > add ns1/ns2.domain.com etc
This is echoed in the initial webmin set-up process, where hostname is set to sunshine.mydomain.tld and additional nameservers are set to ns1.mydomain.tld and ns2.mydomain.tld
I do it this way, is sunshine.mydomain.tld a nameserver?
It is yes… it is also the hostname for the server as set in:
/etc/hosts
/etc/hostname
I think part of the reason I settled on the way I do it is because virtualmin asks for the ‘hostname’ (both on that screen and the virtualmin post-install walkthrough) and I’ve always thought the hostname is the FQDN.
Hostname is the servers hostname, I don’t associate it with the virtual servers.
Nameservers should match what your using at your registrar as well. As long as it matches that fine.
Nameservers I use the stantard ns1.domain.com and ns2.domain.com and that why I have used that in the template.
I wonder if the naming should be different on those virtualmin pages then? I think I settled on this way because I thought virtualmin wanted the server hostname specified there.
(But yes, I have all three set as nameservers at the registrar)
