virtualmin domains dropdown doesn't work
I added the last couple of domains for our server migration. Now there are too many for the dropdown list. Can I change the number of domains the dropdown list will handle?
Yup, System Settings -> Module Config -> User Interface Settings -> “Maximum number of domains to display” should do what you’re after.
Perfect! Thanks Eric. Your prompt responses are always appreciated.
