I am running FC5
Installed Webmin
Installed Vitrualmin
Installed ProFTPD through Webmin
Virtualmin does not detect ProFTPD. It just tells me that that feature is disabled. Everything is working fine. The Bind Apache Mail MySQL
I am running FC5
Installed Webmin
I had the same problem, and solved it changing the “Path to ProFTPD PID file” parameter to “/var/run/proftpd/proftpd.pid”, in System configuration section of ProFTPD module config.
