Virtualmin configuration restore issue
|debian 12
virtualmin gpl 8.1
I just did a full restore after i needed to move to another server…which virtualmin excels at. how3ever the virtualomin configuration itself refuses to restore. it has it’s own compressed file but the system will not import it. any ideas?
Whats exactly is not getting restored?
the configuration..like the scheduled backups, the php settings for the system..everything that’s in the configuration for virtualmin. it has the backujp file it jsut refuses to restoe it..says no server ccan sue the configuration. I wonder if you need to restore the virt config first and then the sites…i rebiult the configuraiton manually it would be nice
The docs on migrating show doing the Virtualmin restore being done first:
virtualmin restore-domain --source /root/backups/virtualmin.tar.gz --all-virtualmin
virtualmin restore-domain --source /root/backups/ --all-domains --all-features
I think the OP is using the GUI to restore which gives you this if you try to restore the virtualmin settings
as you can see the GUI does not allow you to restore the settings, so the command line works the GUI does not
if you restore a domain you get this
as you can see no mention of virtualmin settings. My guess is the GUI will only allow this to happen if you use the single file option in the original backup (not ideal) or the settings are restored per domain and are not noted on the GUI as being restored (but it is implied) So that just leaves the question how do you restore the virtualmin global settings via the GUI ?
well that’s a pita. why make it be able to be made in the gui but have to use the cli to restore it?
no the single file option does ot pull in the config backup..that’s how i retored the server in question
oh and this isn’t jsut gpl pro has the same issue…
Does your backup contain the Virtualmin global configuration in the first place?
That said, when you made the backup, did you check all the boxes under “Global settings → Virtualmin settings” on the “Backup and Restore ⇾ Backup Virtual Servers” page so they would be included in the backup?
always…it jsut refuses to restore it saying one of the server use any of the features.
@hescominsoon Sorry for the delay!
May I ask how you are performing the restore? Are you using the “Backup and Restore ⇾ Restore Virtual Servers” page and pointing to a single .tar.gz file or a directory that contains one file per server? Or are you pointing restore to the directory that contains multiple files? To be clear, if a scheduled backup was configured to create “One file per server,” then global settings are saved in a separate virtualmin.tar.gz file.
Or perhaps you are restoring it through “Backup and Restore ⇾ Backup Logs”?
not using the backups logs version i avhe thred every verwsion of the first iteration.
