Virtualmin, Cloudflare, and DKIM
Hi all,
I would like to be able to enable DKIM for outgoing mail on a specific domain, however Virtualmin refuses to enable it due to the DNS being hosted by Cloudflare as opposed to the local server.
Is there a way of being able to do this with Virtualmin instead of having to manually trudge through how-to guides?
Disable cloudflare, use your own DNS server. Setup DKIM. Test. Swap to cloudflare DNS. Rescan so Cloudflare can copy the updated DNS entries. Enable cloudflare.
Thanks, not reasonable though for my setup due to that disabling cloudflare would have broken web services on the system considerably until it was re-enabled, which is less than ideal.
I trudged through how-to guides and got it going manually.
