Virtualmin cgi execution issues
I am currently running CentOS 5.3 and Virtualmin 3.60 (GPL)
I cannot get perl files to execute through a web browser. I do not get a 404 or any other error when typing in the correct url, just a blank webpage. I have recompiled apache to have the suexec directory be /home, changed permissions, edited httpd.conf and still cannot get it to work. Below are my config and log files:
HTTPD FOR VIRTUAL
SuexecUserGroup "#501" "#502"
ServerName WEBURL.com
ServerAlias www.WEBURL.com
ServerAlias webmail.WEBURL.com
ServerAlias admin.WEBURL.com
DocumentRoot /home/WEBURL.com/public_html
ErrorLog /home/WEBURL.com/logs/error_log
CustomLog /home/WEBURL.com/logs/access_log combined
ScriptAlias /cgi-bin/ /home/WEBURL.com/cgi-bin/
<Directory /home/WEBURL.com/public_html>
Options Indexes IncludesNOEXEC FollowSymLinks
allow from all
AllowOverride All
</Directory>
<Directory /home/WEBURL.com/cgi-bin>
allow from all
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.WEBURL.com
RewriteRule ^(.) http://WEBURL.com:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.WEBURL.com
RewriteRule ^(.
) https://WEBURL.com:10000/ [R]
Suexec.log
[2009-04-13 13:23:37]: uid: (501/WEBURL.com) gid: (502/502) cmd: index.cgi
[2009-04-13 13:23:38]: uid: (501/WEBURL.com) gid: (502/502) cmd: index.cgi
suexec -V
-D AP_DOC_ROOT="/home"
-D AP_GID_MIN=100
-D AP_HTTPD_USER="apache"
-D AP_LOG_EXEC="/var/log/httpd/suexec.log"
-D AP_SAFE_PATH="/usr/local/bin:/usr/bin:/bin"
-D AP_UID_MIN=500
-D AP_USERDIR_SUFFIX="public_html"
File to execute
-rwxr-xr-- 1 WEBURL.com WEBURL.com 41 Apr 13 13:11 index.cgi<br><br>Post edited by: thedatabackup, at: 2009/04/13 14:32
If something isn’t working right, it should show up in the Apache error logs. Do you see anything in ~/logs/error_log at around the time you’re attempting to run the script? That might help in diagnosing the issue.
It does appear that you have suexec working correctly though :slight_smile:
Thanks for the prompt response.
The other logs in /var/log/httpd do not have any information regarding the execution of the file. The server that I am testing on doesn’t have anything else running on it currently, but is able to display other web pages that use server side scripting (PHP).
Any other ideas?
Whenever you create a Virtual Server, it puts a logs directory into the associated homedir, in /home/USERNAME/logs. At that point, any errors would show up in /home/USERNAME/logs/error_log, and not /var/log/httpd.
Do you have an error log in the Virtual Server home directory?
