I recently realized I was running an old MySQL database server version and needed a quick way to upgrade without effecting other things on my system. I was reading this forum and someone was describing how they upgraded to MariaDB using the SCL. It worked great. I did end up re-importing my database but it went OK. Now, when I try to do a backup on Virtualmin it won’t let me backup my database. I have to go into phpmyadmin and pull that separately. I have updated the DB information inside of Webmin/Virtualmin but I am a little concerned I cannot automate a backup of the site and database. Anyone have experience with this?
Just curious: Have you tried running the check configuration tool? I’m just wondering if maybe Virtualmin doesn’t realize you’ve switched from MySQL to Maria.
Thank you for your response. I have checked it and everything went OK, there was even a line indicating it recognized my MariaDB install. When I goto make a backup and select the option to include databases, it halts with this message:
Dumping MariaDB database matamo …
… dump failed!
mysqldump: Couldn’t execute ‘show events’: Cannot proceed, because event scheduler is disabled (1577)
The last post in that thread talks about fixing the issue by running mysql_upgrade. Best you read that thread to see if it applies to your particular situation.
Thank you. I did see that, however, I wasn’t sure about running that command with my SCL installation. I suppose I am confused by it and it has caused me more trouble than if I upgraded normally.
When I google this error, everything indicates you need to run mysql_upgrade as @Gomez_Adams has pointed out. That’s not really a Virtualmin issue…you upgraded mariadb. When upgrading a database, you should read the upgrade docs for that database. It will presumably tell you when you need to run mysql_upgrade (it is not unusual to need to do this when going from one major version to the next).
