Hello, i am trying to integrate autoreply feature that enables auto reply of virtualmin email addresses from a PHP app.
I am running this command to save autoreply parameters entered in PHP app:
If i do the same from Virtualmin > Edit Users > user and save the autoreply text it adds From header as “Real Name” user@domain.com where “Real Name” is the value of field Real name under Virtual domain user details" section.
How can i set autoreply From email to include the name of person when using modify-user API ?
Another bug i found modify-user API.
…&autoreply-start=2018-05-21 00:00:00&autoreply-end=2018-05-21 23:59:59
returns
status “failure”
error “Date spec must be like 2007-01-20 or -5 (days ago)”
It does not accept time. If i set …&autoreply-start=2018-05-21&autoreply-end=2018-05-21 then in the autoreply file under /var/virtualmin-autoreply/ it writes Autoreply-Start: 1526853600
Autoreply-End: 1526853600
However setting 21. May 2018 as start and end from Virtualmin > Edit Users works fine and saves in the file these values:
Autoreply-End: 1526939999
