Along with virtualmin even webmin installs with virtualmin. Can I uninstall webmin ? Any tips to reduce memory usage (256 mb) ?
Virtualmin is a Webmin module… so you have to have Webmin to be able to use Virtualmin.
Yeah, 256MB of RAM is a bit low for running a web server with the full Virtualmin stack. With that little RAM, you’ll definitely be doing a lot of work to keep processes from consuming all of your available RAM.
However, this document here may help:
http://www.virtualmin.com/documentation/system/low-memory
In the “Disable unnecessary services” section, you may want to add “Mailman” to that list. I’d recommend disabling it, along with any other unnecessary services.
