I am trying to setup virtualmin and CSF firewall.
http://configserver.com/cp/csf.html
I have setup virtualmin fine multople times, then i install csf and it installs ok and i load up the webmin module ok, the only problem i have is that it does nothing. I enter ports to allow, ip address to block and so on and nothing, it just dosent work. I have all the required modules installed and functinging as well.
I have noticed that if i enter the IP tables using the firewall thing which is on virtulmin then i can block ports using that, but i want to use csf.
I have tried installing webmin on its own and isntalling csf and that works correctly, only when i install virtualmin it dosent, its as if virtulmin is telling iptables to read from a different place.
