Virtualmin and CentOS 5.4 on Xen, Management Slow.
I have Virtualmin running on CentOS, and the management is very slow. ie. https://192.168.1.100:10000
It can take 15 to 20 seconds to load after login.
Note: I have the same config running Webmin on another server and it works great.
My Machine (VM) has 1G RAM and 2vCPU’s. The CPU usage is practically 0. I have about 9 Virtual Sites running, and they all seem to run fine. Just the management GUI. Any ideas?
Richard
Ok… I fixed the issue…
Turns out my DNS was not configured correctly. Once i set it to 127.0.0.1 the management work perfectly.
Richard
