Just trying to set up the EC2 AMI and am having a problem with the FQDN.
The default is localhost.localdomain.
Leaving it at this, Apache falls over and cannot restart, with the error:-
apr_sockaddr_info_get … failed
Could not reliably determine the server’s fully qualified domain name…
Putting in a FQDN in Webmin > Networking > Network Configuration, I get the error:
For FQDN, I am trying the server name host.mydomain.com, as well as the amazon public DNS hostname…
I’m sure this is something simple, but I’m a bit stumped.
I have been running Virtualmin on a VPS for two years now, with no problems - so there appears to be something different here…
Hrm, I’m surprised you’re seeing problems with Apache starting up. However, one place you might start is to edit your Apache config, and add a “ServerName” entry. Then, if it can’t determine your FQDN, it should fall back to whatever you set in ServerName.
You could also try setting an FQDN for your hostname on the command line, by running this command:
hostname your.fqdn.tld
You’d also want to make sure your server’s hostname exists in /etc/hosts.
Oh, also, if Apache is just silently failing like that when you start it up, you may want to take a peek at the Apache error logs in /var/log… they may list the specific error that’s causing it to not start.
