I’ve virtualmin installed on Ubuntu 14.04. It has eight virtual servers configured since last six months. Everything was working fine till this morning when the virtualmin admin login is no more accessible through browser. It return “Can’t open this page because the server is not responding”. I’ve also tried the IP instead of domain name i.e. https://IP:10000 but still return the same error.
All of the websites are running fine. However, the pop server has also stopped so associated emails can’t be downloaded through gmail client or outlook.
Please help!
Adil
It could be that server crashed during the night and some of the services didnt come back, or you hit memory/cpu limit, or it was (D)DoS attack… and so on. If you can log with SSH you could check if Wmin is up and running if not try to manually start. If you cant start Wmin then next step would be to check log files. For sure something happened because services dont go down without reason.
Thans for reply.
I have logged in through SSH and reboot the server. Still the same issue.
The memory status is given below;
Every 5.0s: free -m Mon Jun 1 11:16:18 2015
total used free shared buffers cached
Mem: 2001 1817 184 375 7 722
-/+ buffers/cache: 1087 914
Swap: 4095 5 4090
I’ve also restarted the webmin by running: /etc/init.d/webmin restart. All servers starts fine!
The individual error logs of the websites shows no error. Where can I find error log for the virtualmin itself?
Adil
Here are some of entries from one of the VS error.log file;
[Fri May 29 00:35:55.860849 2015] [fcgid:warn] [pid 31392] (104)Connection reset by peer: [client 123.125.71.45:36420] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function
[Fri May 29 01:11:02.352621 2015] [fcgid:warn] [pid 19183] (104)Connection reset by peer: [client 125.86.9.250:52335] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Fri May 29 02:58:42.496414 2015] [fcgid:warn] [pid 11356] (70014)End of file found: [client 125.86.9.250:65479] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Fri May 29 05:32:49.316092 2015] [fcgid:warn] [pid 12610] (32)Broken pipe: [client 37.139.52.23:2868] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://viparenda.kz/ru/
[Fri May 29 05:32:51.333290 2015] [fcgid:warn] [pid 1195] (104)Connection reset by peer: [client 37.139.52.23:3042] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://viparenda.kz/ru/
[Fri May 29 05:32:52.526206 2015] [fcgid:warn] [pid 13119] (104)Connection reset by peer: [client 37.139.52.23:3129] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://viparenda.kz/ru/
[Fri May 29 05:48:03.790230 2015] [fcgid:warn] [pid 1195] (32)Broken pipe: [client 37.139.52.23:1966] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://igru-xbox.net/
[Fri May 29 09:11:02.042160 2015] [fcgid:warn] [pid 26929] (104)Connection reset by peer: [client 125.86.9.250:54597] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Fri May 29 13:28:13.269730 2015] [fcgid:warn] [pid 7635] (104)Connection reset by peer: [client 94.153.10.249:64084] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://feminissimo.ru/
[Fri May 29 14:01:45.686485 2015] [fcgid:warn] [pid 8780] (104)Connection reset by peer: [client 37.115.185.94:51511] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://www.knigonosha.net/
[Fri May 29 17:10:59.709005 2015] [fcgid:warn] [pid 16886] (70014)End of file found: [client 125.86.6.169:63026] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Fri May 29 19:00:26.047411 2015] [fcgid:warn] [pid 18800] (70014)End of file found: [client 125.86.6.169:62737] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Fri May 29 20:39:17.818392 2015] [fcgid:warn] [pid 26150] (104)Connection reset by peer: [client 123.125.71.70:59883] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function
[Fri May 29 21:08:32.406269 2015] [fcgid:warn] [pid 27431] (104)Connection reset by peer: [client 94.153.10.249:53617] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://freewhatsappload.com/
[Fri May 29 21:35:39.544406 2015] [fcgid:warn] [pid 27431] (104)Connection reset by peer: [client 94.153.9.220:51126] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://salutmontreal.com/
[Sat May 30 01:52:02.604898 2015] [fcgid:warn] [pid 540] (104)Connection reset by peer: [client 46.118.239.173:2789] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://kazrent.com/
[Sat May 30 02:53:04.260857 2015] [fcgid:warn] [pid 8276] (70014)End of file found: [client 125.86.6.169:64022] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Sat May 30 03:03:12.413761 2015] [fcgid:warn] [pid 10074] (70014)End of file found: [client 125.86.6.169:49975] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Sat May 30 07:38:55.273195 2015] [fcgid:warn] [pid 16366] (104)Connection reset by peer: [client 94.153.9.220:54458] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://forsex.info/
[Sat May 30 07:57:38.156885 2015] [fcgid:warn] [pid 16368] (104)Connection reset by peer: [client 220.181.108.150:57085] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function
[Sat May 30 10:56:26.069141 2015] [fcgid:warn] [pid 22429] (70014)End of file found: [client 125.86.6.169:52815] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Sat May 30 13:31:24.883038 2015] [fcgid:warn] [pid 2826] (32)Broken pipe: [client 37.115.185.94:52912] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://taihouse.ru/
[Sat May 30 13:31:26.971180 2015] [fcgid:warn] [pid 24951] (104)Connection reset by peer: [client 37.115.185.94:55863] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://taihouse.ru/
[Sun May 31 03:06:05.609351 2015] [fcgid:warn] [pid 7975] (70014)End of file found: [client 125.86.10.133:55717] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Sun May 31 03:51:55.607516 2015] [fcgid:warn] [pid 7969] (32)Broken pipe: [client 69.164.111.198:10039] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://fnpk.org/
[Sun May 31 07:43:54.963910 2015] [fcgid:warn] [pid 18074] [client 157.55.39.122:29802] mod_fcgid: stderr: PHP Notice: Undefined index: abspath in /home/fnpk/public_html/wp-content/plugins/tts-engine-post-to-speech/tts-engine-get-safari-urls.php on line 8
[Sun May 31 07:43:54.964703 2015] [fcgid:warn] [pid 18074] [client 157.55.39.122:29802] mod_fcgid: stderr: PHP Warning: require_once(wp-load.php): failed to open stream: No such file or directory in /home/fnpk/public_html/wp-content/plugins/tts-engine-post-to-speech/tts-engine-get-safari-urls.php on line 9
[Sun May 31 07:43:54.964732 2015] [fcgid:warn] [pid 18074] [client 157.55.39.122:29802] mod_fcgid: stderr: PHP Fatal error: require_once(): Failed opening required ‘wp-load.php’ (include_path=’.:/usr/share/php:/usr/share/pear’) in /home/fnpk/public_html/wp-content/plugins/tts-engine-post-to-speech/tts-engine-get-safari-urls.php on line 9
[Sun May 31 09:07:45.244223 2015] [fcgid:warn] [pid 17831] (104)Connection reset by peer: [client 54.204.199.49:58538] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://www.traackr.com/
[Sun May 31 10:22:57.984800 2015] [fcgid:warn] [pid 18074] (32)Broken pipe: [client 94.153.10.249:54125] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://urth.ru/
[Sun May 31 10:22:58.854744 2015] [fcgid:warn] [pid 27093] (104)Connection reset by peer: [client 94.153.10.249:59469] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://urth.ru/
[Sun May 31 10:23:59.507899 2015] [fcgid:warn] [pid 22450] (32)Broken pipe: [client 37.115.185.94:64128] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://viel.su/
[Sun May 31 10:24:02.107497 2015] [fcgid:warn] [pid 27092] (104)Connection reset by peer: [client 37.115.185.94:59370] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://viel.su/
[Sun May 31 13:40:28.735424 2015] [fcgid:warn] [pid 1039] (104)Connection reset by peer: [client 54.204.199.49:34046] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://www.traackr.com/
[Sun May 31 17:33:31.355681 2015] [fcgid:warn] [pid 10497] (104)Connection reset by peer: [client 94.153.10.249:52896] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://howopen.ru/
[Sun May 31 17:33:31.433374 2015] [fcgid:warn] [pid 9626] (104)Connection reset by peer: [client 94.153.10.249:62857] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://laxdrills.com/
[Sun May 31 17:33:32.430356 2015] [fcgid:warn] [pid 11580] (104)Connection reset by peer: [client 94.153.10.249:58673] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://howopen.ru/
[Sun May 31 17:33:32.456804 2015] [fcgid:warn] [pid 9156] (104)Connection reset by peer: [client 94.153.10.249:57530] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://laxdrills.com/
[Sun May 31 17:33:33.804064 2015] [fcgid:warn] [pid 9626] (104)Connection reset by peer: [client 94.153.10.249:56858] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://howopen.ru/
[Sun May 31 19:05:31.245177 2015] [fcgid:warn] [pid 16702] (70014)End of file found: [client 125.86.10.133:54554] mod_fcgid: can’t get data from http client, referer: http://www.fnpk.org/board-of-advisers/#comment-182++++++++++++++++Result:+success+-+posted+to+first+encountered+partition+“http://www.fnpk.org/board-of-advisers/”;+message+must+go+through+moderation;
[Mon Jun 01 04:29:45.894014 2015] [fcgid:warn] [pid 9999] (32)Broken pipe: [client 37.115.185.94:64072] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://iphone6-mobile.com/
[Mon Jun 01 04:29:47.750971 2015] [fcgid:warn] [pid 10241] (104)Connection reset by peer: [client 37.115.185.94:53636] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://iphone6-mobile.com/
[Mon Jun 01 10:42:04.833305 2015] [fcgid:warn] [pid 9736] (104)Connection reset by peer: [client 37.115.185.94:50772] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://taihouse.ru/
Could you please see any problem in here? I can see some weird links in errors related to mod_fcgid. What do they mean?
Thanks,
Adil
Log files should be where Ubuntu usually store all other log files, not sure as i never used Ubuntu but on Centos that is /var/.
If you start Wmin you could just login and check the log files from the control panel. If Wmin cant start then you could try to restart entire server and see if all services will boot up with the server. If the problem is still present then i would suggest to wait for Wmin guys. Either way for what i can see the memory is not the problem.
Eric
June 1, 2015, 2:36pm
6
It’s just Webmin/Virtualmin that isn’t accessible, is that correct? The websites themselves are working fine?
If so, you may want to take a look at the Webmin logs, which you can see in /var/log/miniserv.error.
Also, you can verify that Webmin is running on the standard port with this command:
netstat -an | grep :10000
Lastly, you may want to make sure there isn’t a firewall blocking that port. You can see all your firewall rules with the command “iptables -L -n”.
