I think maybe that decides it for us. Webalizer is the one we remove from the default install. I guess AWstats is still there? Maybe we remove both?
Yes, awstats is still available. I don’t think we should remove both.
OK, we’ll keep AWstats, drop Webalizer by default, assuming Virtualmin is smart enough to hide the feature (since it’s built-in rather than a plugin).
I think we actually need this patch, and this patch, and this patch, and this patch.
Is there anything else?
When Virtualmin 7 is fully released you wouldn’t have to bother but if you need to install Virtualmin 6 right now, you should still follow my instructions above, as an old stack package would still want that missing in Debian 11 webalizer package.
Any idea about the “when” ? (I know you do not give dates but I start to need real bad to order new machines and it does not make sense for me to order Debian 10 …) ![]()
I would presume it must be out by by the end of this week (Sunday 27).
Good news !! Thanks for the great work !
Pierre
It looks like it wasn’t building so it was auto-removed for the bullseye freeze:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=957923
https://tracker.debian.org/pkg/webalizer
It might be worth it to either mirror the testing/unstable package for users or ask it to be added to backports for bullseye. Users upgrading from debian 10 may still have it installed w/o any chances of security updates…
Does anybody use webalizer, anymore? I considered removing either AWstats or Webalizer or both as far back as Virtualmin 6, and we’re definitely removing webalizer now, since it doesn’t even exist on all platforms.
We don’t like depending on things that are not well-maintained, as we always catch the blame for brokenness or security issues if we had anything to do with it being installed. (Hell, we catch the blame for broken system updates totally unrelated to Virtualmin, just because we show available updates in the UI. But, part of our job, I think is curating a good set of default decisions for a server, and I don’t really consider webalizer a good decision today.)
With its last stable release 8 years ago, I really think nobody does. At least nobody interested in the latest version of Virtualmin and Debian. ![]()
I’ve been hosting websites for 23 years and I regard Webalizer as a utility whose only function is to waste disk space. AWstats I find more useful and less resource intensive, so my vote to to let Webalizer RIP and retain AWstats.
What if Matomo (an already existing Install Script in Pro) came to Virtualmin GPL? Could we get rid of AWStats, too?
I just checked and found that AWstats hasn’t been updated in almost two years, so perhaps it’s going the same way as Webalizer. I don’t have experience of Matomo but it looks good. As long as it’s not bloatware, I’d be happy to see it in place of AWstats.
Does this mean that the recently-released Virtualmin 7 will soon become VM7.0.1?
Virtualmin 7 isn’t quite released. The module has been tagged, but it’s not in Virtualmin repos until later tonight, and the VM 7 installer probably won’t come until tomorrow some time.
In that case the website is misleading. Under ‘Latest News’, it says ‘Virtualmin 7.0 released’ and after the description, it gives the date as ‘March 23, 2022’.
The Virtualmin page has a ‘Virtualmin Installer’ link below the heading ‘Download Virtualmin 7.0’. Further reading of the linked page advises that: “Ideally, it should be run on a system that has a fresh install of either CentOS 5, Debian 4.0, Ubuntu 8.04 or Solaris as at the moment those are the only supported operating systems.”
This may discourage new users to take up Virtualmin, as it gives the impression that the project is old and possibly unmaintained, wheras the opposite is the truth.
Looking forward to the real release!
What website?
Edit: Oh, you mean Webmin.com. That’s not the Virtualmin website. I even thought we’d removed the Virtualmin section of Webmin.com because it is so misleading and out of date. It will be removed at some point. The module updates will continue to get posted there just because it’s part of Jamie’s process.
I’ve been using Matomo for many years and it’s a good analytics software but in order to use it, my client / the owner of a website must add javascript to each page. It is for this reason that it differs from log processing software like AWststs / Webalizer. For my clients, AWstats is a value added service which just works - and works without my client needing to modify his website in any way.
If AWstats / Webalizer is to be replaced with Matomo in Virtualmin 7 then the devs should integrate Matomo deeply enough with Virtualmin such that Matomo processes logs and can therefore be used for analytics without the need for a client / website owner adding JavaScript to every page of his website. This should be easy for the devs to do as there is already a log import option built into Matomo; the devs need to put it in a cron and test it thoroughly. If Matomo can be used as a log processor for rudimentary analytics, it would be a great new feature of Virtualmin 7, since it’s user interface and feature set is superior to AWstats / Webalizer.
Another thing to keep in mind is the emerging trend of web bowsers focussing on privacy and therefore giving out less and less info for analytics with newer versions of Chrome, Safari et al. In a cookieless future, might we not need tools which can process raw logs?
calport is right, Matomo differs from AWstats, as it works like Google Analytics (you have to include it in your website code), while AWstats just processes log files. Very different approach. I think they each have its place and are not interchangeable.
