Login panel loads fast but webmin never finish loading. It present background color but never loads. I restart webmin process but get the same.
Thanks.
Thanks.
OK, I found the problem. rootfs is full.
I discover that the cause of the problem is /root/maildir/new. This directory has thousands of emails and is using about 8 GB of space.
Of course i can delete all files. But i’m worry the server get stuck on the process because the many smal files that has to delete. You know some strategy to delete blocks of files?
Thanks.
OK i’m manually deleting files in blocks and is working. This is solved.
Thanks.
