Good afternoon,
I created several virtual servers some work as expected but others not so much, and settings that are saved do not apply for a specific virtual server.
under Show Webmin switch in navigation menu? is set to No
however, the Webmin tab still shows when logged in as that user and also the virtual server that was created has access to the global PHP settings…
This seems like a bug, even though you cannot save it, the buttons Manage and Edit Manually should not be displayed for global PHP config, right @Jamie?
