Virtual host not working
Hi there,
I’m new to Webmin and Virtualmin.
I have a VPS where I want to host some of my domains. I installed Debian 6, updated and upgraded before I installed Webmin.
I continued with installing Virtualmin and going through the “re-check” and fixing the errors it would give me.
So far, so good. Everything seemed to work as it should, so I created my first virtual host. It worked and showed me the standard “index.html” file when I visited my domain.
(For some reason it was loading really slow?)
I then proceeded with uploading my files, replacing “index.html” with my own “index.php” file, but now it does not work?
When I go to my domain, instead of showing the index.php file, a download window pops up, asking me if I want to download the file “download”.
The file “download” is my index.php file, simply renamed for some reason.
I hope someone can help me with this, as I have spend several hours re-installing and what not…
it is not clear how you installed virtulmin? But I guess you didn’t run the automatic installation with “install.sh”, right? This would install virtualmin and webmin automatically.
Please reset your VPS and try again with install.sh (see also documentation)
