i try to migrate from ISPConfig to virtualmin. For this purpose I’ve setup a test customer called test.yz.
The admin of this (virtual) site is able to add new email users. Unfortunately virtualmin does not create the necessary entry in
/etc/postfix/virtual. I (root) have to do this step by hand which is quite painful if you have hundreds of customers.
(while bert.test needs to be a real user on the underlying system)
Why does virtualmin not automatically modify the ‘virtual’ file ? Is that normal ?
The only workaround is to grant postfix admin rights to that site-admin which is not suitable because he can modify everything which concerns postfix.
kind regards,
Jan
used versions :
webmin 1.412
webmin-virtual-server 3.57.gpl-2
oh sorry it was my fault. I clicked the wrong button while adding the new user.
“Add a website FTP access user.” instead of “Add a user to this server.” Now the entry in the ‘virtual’ postfix file is being made correctly.
Dammned. Your software works perfectly. Thank you !
