Is there a way to verify all installed virtualmin packages without upsetting a typical installation?
For example, in rpm-based systems you could do:
rpm -Va
to verify all installed packages. On debian-based systems, you can use
sudo debsums -c
or
sudo debsums_init
to check for changed files or re-install and verify all packages.
The question is, because virtualmin, webmin etc installs custom versions of typical server packages, is it a risk to run an automated re-install like this?
Thanks.
