SYSTEM INFORMATION | |
OS type and version | Debian 12 |
Webmin version | 2.101 |
Virtualmin version | 7.8.2 Pro |
Related packages | Let’s Encrypt |
I was reading up on the advantages for using Elliptic Curve for the certificate. I tried doing this on one of my sites and was greeted with the following message.
Renewing an existing certificate for twin-peaks-video.com and www.twin-peaks-video.com
Unable to change the --key-type of this certificate because --reuse-key is set. To stop reusing the private key, specify --no-reuse-key. To change the private key this one time and then reuse it in future, add --new-key.
Here is the entry in the log file.
2023-11-05 09:44:09,930:DEBUG:certbot._internal.plugins.selection:Requested authenticator manual and installer <certbot._internal.cli.cli_utils._Default object at 0x7f59613ba890>
2023-11-05 09:44:09,930:DEBUG:certbot._internal.cli:Var key_type=ecdsa (set by user).
2023-11-05 09:44:09,930:DEBUG:certbot._internal.cli:Var certname=twin-peaks-video.com (set by user).
2023-11-05 09:44:09,931:DEBUG:certbot._internal.display.obj:Notifying user: Renewing an existing certificate for twin-peaks-video.com and www.twin-peaks-video.com
2023-11-05 09:44:09,958:DEBUG:certbot._internal.log:Exiting abnormally:
File "/bin/letsencrypt", line 33, in <module>
sys.exit(load_entry_point('certbot==2.1.0', 'console_scripts', 'certbot')())
File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
return internal_main.main(cli_args)
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1736, in main
return config.func(config, plugins)
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1590, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 126, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 385, in renew_cert
_avoid_reuse_key_conflicts(config, lineage)
File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 372, in _avoid_reuse_key_conflicts
raise errors.Error(
certbot.errors.Error: Unable to change the --key-type of this certificate because --reuse-key is set. To stop reusing the private key, specify --no-reuse-key. To change the private key this one time and then reuse it in future, add --new-key.
2023-11-05 09:44:09,958:ERROR:certbot._internal.log:Unable to change the --key-type of this certificate because --reuse-key is set. To stop reusing the private key, specify --no-reuse-key. To change the private key this one time and then reuse it in future, add --new-key.
