The directory /etc/usermin either does not exist on your system, or is not the Usermin configuration directory. Maybe Usermin is not installed, or your module configuration is incorrect.
My usermin configuration directory is set to this:
I don’t have much to add beyond that error. Either this directory doesn’t exist or it doesn’t contain the necessary files.
How did you install Usermin? (Note that Usermin is a separate application from Webmin and Virtualmin, and if you didn’t install using our one of our Virtualmin install scripts, it may not actually be installed.)
