Usermin Customization
Hello Dear All,
I am interested in Usermin customization. Please guide me in this direction.
Regards,
Krishna.
Well, what is an example of something you would like to customize?
Dear Eric,
Thanks for reply.
Well i want following to be customized for the first stage:
  1. Login Page: I want to put logo of my choice and put color or background images.
  2. Read Mail Page: I want to put logo of my choice and put color or background images. and also there are double buttons for all options like Compose, delete etc. how to make single button options for all mailing options?
  3. Make and administer mail ids from Webmin or Usermin.
Thanks.
Regards,
Krishna.
Well, you can make some Usermin customization in Webmin -> Webmin -> Usermin Configuration.
However, I’m not sure that you can make any of the changes you mentioned – that may require changes to the Usermin theme.
Dear Eric,
Like i can change the text of Usermin login page from:
/usr/libexec/usermin/ulang/en
similarly Is there any file where i can edit the contents to do above stated changes.
Regards,
Krishna
Well, there isn’t a good way to do that without creating a new theme… if you just modify the existing theme, that’ll be overwritten next time Usermin is updated.
However, you could make edits like that if you don’t mind them being overwritten – you’d just need to find the correct files to edit in /usr/libexec/usermin/.
Sorry, I don’t know which files those are, that’s part of the challenge here :slight_smile:
Some question for usermin when send email address out
Sending mail to “Finance - xx” user@xxx.com , “’ KMN - xxx’” user@xxx.com , “‘user@xxx.jb’” user@xxx.com
Failed to send mail : SMTP command rcpt to: user@xx.jb failed : 450 4.1.2 user@xx.jb: Recipient address rejected: Domain not …
