I was sure this would be an existing issue.
Just installed to Rocky and are only using SSH to login as root so we don’t have root password.
Please refer me to an article about how to add a user to manager the virtualmin GUI environment.
I am a pro user and don’t know where to add that information in the required information.
Thank you for this reference. This is going to make all the difference. One more question.
If I type in the following command will this give me a global virtualmin admin to have access to manage the entire virtualmin environment, all virtual servers, and accounts?
I hope your using SSH keys to login as root(so you can disable password login), I presumed that what you meant and you want someone else as a extra administrator.
Sorry, missed you response, a close look at the command you added, you using inverted commas and that seems to be wrong, maybe the copy and paste did that, let me try in putty…don’t look like it is. Make sure you use --desc “my virtualmin admin” not --desc “my virtualmin admin” as the error is saying unknown flag of virtualmin and that the only place it is.
I hope you understood that
this may show you what I mean
P.S. looks like the editor on here shows no difference, the screenshot does.
If you’re typing code, command lines, etc., use backticks ` to wrap the code, or use triple backticks for multi-line code sections. This forum uses Markdown.
When you to that the code can be copied and pasted without any weirdness.
