User account spam header and body tests
Usermin version 2.102
Virtualmin version 7.20.2 Pro
Theme version 21.20.7
Apache version 2.4.52
Package updates 49 package updates are available
Virtualmin --> Mail Options --> SpamAssassin Configuration --> Header and Body Tests
Has any one got this to work, I have tried but they don’t seem to work.
Yep I got it to work, most are in the webmin section. What are you trying to do?
not it webmin, in virtualmin. it is a different part of the process.
Yeah but it should still work, but it would only effect that domain. What rule have you tried that is not working. (so I can test)
I actually do have one rule
can’t remember doing it, I must of has alot of emails from that domain.
just did a test from my gmail account with this rule.
The test I did was for the word claudia in the message body, it did not work.
I want to user per user filtering as this is where I get most of my spam.
You are using spamassassin not spamc right? I use spamc so if I put rules there they are ignored.
Virtualmin > Email Settings > Spam and Virus Scanning
Good call I forgot about that. My current settings are as below so I don’t think it is this.
post the rule, I’ll replicate it. I don’t use spamc
per user would prob be done is usermin. Not sure how you would do that in virtualmin.
thanks. I only used simple
trying use a better testname, 1 did not work for me, this worked though.
Test name will also error with any spaces. Does it still work with no description?
like:
APECOIN_BODY
I see it just puts no description available.
These are not predefined spam assasin tests, but is having the test names lowercase the issue.
I will see if lack of description causes an issue.
@stefan1959 example worked with lower case and just added :no decription available.
quote from :
https://spamassassin.apache.org/full/3.1.x/doc/Mail_SpamAssassin_Conf.html
Test names must not start with a number, and must contain only alphanumerics and underscores. It is suggested that lower-case characters not be used, and names have a length of no more than 22 characters, as an informal convention. Dashes are not allowed.
Spamassassin docs are too complex. I get lost in them.
When i first started setting mine up I read somewhere that if it didn’t like the way a rule was formatted it would skip that rule and continue skipping rules and eventually start reading rules again. I figure since they use ALL_CAPS and underscores so will I. I just copy/paste the rule name as the description. My rules work. I have a lot of rules and weight a lot of their rules.
toward the bottom under TEMPLATE TAGS
is a list of X-Spam headers you can add to your header
It could be the test name, thanks. I will try tommorow.
There should be a validator on the test name field in virtualmin.
I was using test names starting with a number.
I have submitted a couple of GitHub issues for this
