Use same directoy for two virtual servers
I want to use the same directory for the two servers.
Is it possible with the virtualmin
Can the second one be an alias?
An alias server uses the same DocumentRoot as the parent Virtual Server.
You can create an alias in the “Create Virtual Server” area, and there you can make either a regular alias, or an alias with separate email.
thanks Eric.
