Use pre-existing unix user
Hi there,
Is it possible to use a pre-existing unix user to create a virtual server, or do I have to delete the original user and re-create it with virtualmin?
Cheers.
you can convert a unix user through the webmin users module.
That’s what I did, but i still cannot/don’t know how to create a primary virtual server with that pre-existing user account.
did you assign that user to a group when converting? The user will get the permissions that the group allows him.
I did. In any case, i decided to just delete the user and re-create it with the virtual server.
Thanks any way :slight_smile:
