SYSTEM INFORMATION | |
OS type and version | Redhat Enterprise Linux 8.8 |
Webmin version | 2.101 |
Usermin version | 2.001 |
Virtualmin version | 7.8.2 |
Theme version | 21.04 |
Package updates | 26 package updates are available, of which 3 are security updates |
I want to use a commercial cert I already have for sub-servers under a virtual server – our development group has a three part domain assigned to them – wphost01.anywhere.com – and for their DEV work, they create four part names such as verne.wphost01.anywhere.com. So I want to automatically configure and use the existing cert *.wphost01.anywhere.com.
One thing I tried but failed, plus is very crude and ugly — placed the commercial cert/key/chain files in a directory (such as /etc/pki/tls/xxxxx/) and then made all three files immutable with chattr +i xxxxx
. Then made a custom Sub-Server Template, and in that template, on the SSL Website pulldown panel, manually entered my full path and filename for the key/cert/CA cert (aka chain) into each of the Custom Path fields. This does create a new self-signed cert in the specified files, overwriting the commercial cert, unless I have the immutable bit set, as the immutable bit stops Virtualmin from being able to write/update those files – but see below.
I thought the immutable trick would work, but the Apache SSL website module (?) fails during the sub-server creation as it can’t create the self-signed cert; the failure does display an error message and then causes the entire ssl apache stanza to not be created (rightfully so I suppose) – note the port 80 stanza does get created.
Before I start hacking away at php code, I wanted to get input in case I have missed something
And this could be such a one-off usage case (plus how would I describe it) that I hesitate to submit it as an enhancement request or blue sky post.
