Upgrade to Virtualmin pro 404 link
Virtualmin version 6.17
Hi, just want to say that on Virtualmin > System Settings > Upgrade to Virtualmin Pro, there is a text:
If you have enjoyed using Virtualmin GPL and want to take the next step to the Pro version, this page can be used to perform the upgrade process automatically. The steps to do this are :
  1. Go to Shop – Virtualmin and purchase a license for Virtualmin Pro.
  2. Enter your serial number and license key in the form below.
  3. Click the Upgrade button. This will download all of the latest Virtualmin modules, and add them to your Webmin install. All of your existing settings will be left un-changed, and no other software installed.
Shop – Virtualmin page no longer exists, I believe it should be directed to https://www.virtualmin.com/shop/
Oh, you’re right. I’ve added a redirect.
Thanks for the heads up!
Thanks, although new Virtualmin release will point to /shop by default.
