Although I have 7.0-4 running now, when I had 6.x it also didn’t work.
The only clue I have is I started off with Pro, which worked for a long time. Then when the licensing server bombed I downgraded to GPL. I believe somewhere along the lines this is where it went wrong, but it’s too long ago so I can’t remember.
See the screenshot. Pro features still not enabled, even after logging in and out. Please help?
Hi there, thanks so much for the reply. The output is:
/root]> cat /etc/apt/sources.list.d/virtualmin.list
deb http://xxxxxxx:xxxxxx@software.virtualmin.com/vm/6/gpl/apt virtualmin-focal main
deb http://xxxxxxx:xxxxxx@software.virtualmin.com/vm/6/gpl/apt virtualmin-universal main
@Ilia just tagging you so long. When I compare those values to my shop license, it appears different. Also perhaps this is confidential info, I should probably mask it?
Yes, you should never share active license details in public posts! Although, that was an expired license, not a big deal then.
Go to your Virtualmin.com -> My Account find your active license and copy to the clipboard the change license command and execute it on your server. Afterwards, upgrading to Pro must work.
> virtualmin change-license --serial xxxxxxx --key yyyyyyyy
GPL repos detected. Use `System Settings ⇾ Upgrade to Virtualmin Pro` in UI instead to upgrade first!
Updates the Virtualmin Pro license for this system.
virtualmin change-licence --serial number
--key id
[--no-check]
[--force-update]
So basically I’m back to where I started. I’m guessing I need to specify Pro repos, but I have no idea!
