Is possibile to setup a point of restoration before upgrade via virtualmin? Then, using virtualmin upgrade, every upgrade as security for ubuntu 8.04, will be installed? or the virtualmin upgrade is limited only to program realated to it? thanks
neorf
Sure, you can use Virtualmin’s UI to install any package that needs updated on your system.
However, there isn’t really a way to setup a “point of restoration”. If you want that, you’d need to simply make a good backup of your server first
