root@v2:/usr/share/webmin# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 1.9G 384M 1.5G 22% /
udev 10M 0 10M 0% /dev
tmpfs 202M 284K 202M 1% /run
/dev/mapper/v2-root 1.9G 384M 1.5G 22% /
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 403M 0 403M 0% /run/shm
/dev/vda1 228M 20M 197M 10% /boot
/dev/mapper/v2-home 15G 6.1G 8.2G 43% /home
/dev/mapper/v2-tmp 1.9G 35M 1.8G 2% /tmp
/dev/mapper/v2-usr 1.9G 1.2G 640M 65% /usr
/dev/mapper/v2-var 1.9G 836M 988M 46% /var
root@v2:~# aptitude upgrade -y
The following packages will be upgraded:
webmin
1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/26.2 MB of archives. After unpacking 315 kB will be used.
Reading changelogs… Done
(Reading database … 112462 files and directories currently installed.)
Preparing to replace webmin 1.740 (using …/archives/webmin_1.750_all.deb) …
Unpacking replacement webmin …
dpkg: error processing /var/cache/apt/archives/webmin_1.750_all.deb (–unpack):
unable to create /usr/share/webmin/backup-config/config.info.hu.dpkg-new' (while processing
./usr/share/webmin/backup-config/config.info.hu’): No space left on device
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Webmin install complete. You can now login to https://v2:10000/
as root with your root password, or as any user who can use sudo
to run commands as root.
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install. Trying to recover:
root@v2:~# aptitude upgrade -Z -y -s
webmin <+315 kB>
Would download/install/remove packages.
