Update Problems
I logged into Virtualmin this mornign to find there are updates
when I click "install all updated now"
I get the below errors
just wondering something neeeds to be fixed
Cheers
Colin
Now updating webmin-virtual-server …
  Installing package(s) with command apt-get -y --force-yes -f install webmin-virtual-server ..
  Reading package lists...
  Building dependency tree...
  The following packages will be upgraded:
  1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
  Need to get 2101kB of archives.
  After unpacking 84.9MB of additional disk space will be used.
  WARNING: The following packages cannot be authenticated!
  Err http://software.virtualmin.com virtualmin-etch/main webmin-virtual-server 3.43
    404 Not Found
  .. install failed!
Now updating webmin-virtual-server-theme …
  Installing package(s) with command apt-get -y --force-yes -f install webmin-virtual-server-theme ..
  After unpacking 1049kB of additional disk space will be used.
  Err http://software.virtualmin.com virtualmin-etch/main webmin-virtual-server-theme 4.3
    404 Not Found
  .. install failed!
Hi people,
I’m having similar problems.
Just tried to update scripts and got these errors:
1.Upgrading MediaWiki to version 1.6.7
FAILED
Requires PHP5
2.Upgrading phpBB to version 2.0.21 …
  PHP module pgsql is required ..
        Enabling module in PHP configuration ..
        .. done
  Module is not available even after installation!
  1. Would we not have PHP5 on the system by now? (Seems its been around a long time)
  2. Similar problem?
Cheers,
Himagain
Had similar problems from the command line. Currently on Etch - Virtualmin 3.41.
sources.list:
deb http://XXXXXX:XXXXXXX@software.virtualmin.com/debian/ virtualmin-sarge main
apt-get error:
sb:~# apt-get upgrade
Reading package lists… Done
Building dependency tree… Done
The following packages have been kept back:
libkrb5-17-heimdal
apache2.2-common clamav clamav-base clamav-daemon clamav-docs clamav-freshclam clamav-testfiles libapache-mod-php4
libapache2-mod-php4 libclamav2 libkadm55 libkrb5-dev libkrb53 libpq-dev libpq4 php4 php4-cgi php4-cli php4-common
php4-gd php4-mysql php4-pgsql postgresql-7.4 postgresql-client-7.4 webmin-virtual-server webmin-virtual-server-theme
26 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 4201kB/31.8MB of archives.
After unpacking 266MB of additional disk space will be used.
Do you want to continue [Y/n]? WARNING: The following packages cannot be authenticated!
Install these packages without verification [y/N]? y
Err http://software.virtualmin.com virtualmin-sarge/main webmin-virtual-server 3.43
404 Not Found
Err http://software.virtualmin.com virtualmin-sarge/main webmin-virtual-server-theme 4.3
404 Not Found
Failed to fetch http://XXXXXX:XXXXXXX@software.virtualmin.com/debian/debian/dists/virtualmin-sarge/main/binary-i386/webmin-virtual-server_3.43_all.deb 404 Not Found
Failed to fetch http://XXXXXX:XXXXXXX@software.virtualmin.com/debian/debian/dists/virtualmin-sarge/main/binary-i386/webmin-virtual-server-theme_4.3_all.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Uhhhhh you do realize that you just posted your username and password for your VM license ? Not smart dude…
No, I didn’t realize that. And in fact I can’t seem to edit it. Sweet.
Yeah, we’re moving off of Fireboard as soon as possible (sometime this coming week). I just have to write a new migration script, and finish figuring out which forum we’ll be switching to (SMF is the front-runner at the moment, but it has its own issues).
Don’t worry about the license data. I’ve sanitized it, and will issue Daniel a new license shortly and send along details on how to update your box with the new info. It’s not a big deal (I’ve been toying with PHP regexes to see if I can write a filter that will automatically sanitize any such mentions in th future…it happens about once every month or so, and will probably become more common in the future as our userbase (hopefully) increases in size).
I believe this problem has been resolved in the Debian/Ubuntu repositories. It was a bug introduced in my repository maintenance script while adding a new repository for the GPL version of Virtualmin.
Apologies for the inconvenience.
We had the same error. Two options to fix that at https://www.virtualmin.com/node/38276#comment-756064
