Undefined subroutine &ldap_useradmin::ldap_connect
Using qmail+ldap. LDAP Users and Groups works fine. When I try to run the check config, below are my results. Is this a bug? Or is there a problem with my configuration?
Mail server Qmail with LDAP is installed and configured.
Apache is installed.
Webalizer is installed.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
Using network interface 192.168.121.10 for virtual IPs.
User quotas are enabled for home and email directories, but group quotas are not. Total virtual server quotas will not be enforced.
HTTP/1.0 500 Perl execution failed Server: MiniServ/0.01 Date: Tue, 2 May 2006 20:15:51 GMT Content-type: text/html Connection: close
Error - Perl execution failed
Undefined subroutine &ldap_useradmin::ldap_connect called at /usr/libexec/webmin/virtual-server/check.cgi line 395.
Forgot to mention this is in Virtualmin GPL version 2.611
Hi Sun,
Is this a bug?
Definitely. If you see a perl execution error, it’s a bug. No matter how wrong your configuration might be, you should always get clean execution–errors should come from Virtualmin, and not the Perl interpreter.
Thanks. I submitted a bug report.
